Fishing line advice
atish.rowjee
Hi gents,
I need some advice on re-lining my carp reels. I want to buy new line, however I am not sure what line to buy? I want a line that is a good quality and that will last me a long time.
Also, I need to know how to spool the new line on to my reel without the hassle of twists and tangles?
Please, your advice will really help.
Thanks gents. :fishn
Psy
Atish
PM Enigma, hes the carp specialist and will offer you good advice for new-on-the-market lines.
Just remember: off the top, on the top. Meaning, off the top of the spool and onto the top of the reel, this will eliminate any twist while spooling.
Welcome to Sealine and ......Tight lines
FRITZABU
May be this can help :
After securing the knot by pulling it tight, trim the tag end so that ¼ inch of line remains above the second knot (this extra line keeps the knot from coming loose).
Close the bail so that the reel is engaged and ready to begin winding line onto the spool. If you have a friend available, have them hold the spool with the front side facing you, making sure that they keep plenty of tension on the line. If you are alone when doing this, try running the line through the pages of a phone book to keep the line tight.
I prefer that the line come off the spool counter-clockwise. The reason for this is because when you cast a spinning reel like my Abu Garcia Cardinal 804, the line comes off clockwise. By having the line come off the line spool counter-clockwise, it helps tame some of the line twist. Keeping tension on the line, I begin to wind the reel handle and fill the reel spool. Keep an eye on the reel spool to make sure that the line is filling the spool evenly and fill the spool within 1/8 to 3/16 of an inch from the edge. Too much or too little line will affect the reel’s performance. Once the reel is spooled, cut the line from the remaining line in the package and tie on your favorite lure.
Atish, Fritz has the process right but with the dynamics of a spinning reel and the way it casts line off and then winds it back on it will always wind your line up
As discussed in your PM 0.30mm will also over time develop line twist as the length of line in the water creates resistance and the swivel won't operate at 100% as the lines resistance to the water will prevent the line to roll in the swivel
To counter this, you should between sessions look to walk off 100m of line and reel it back onto the reel (keeping tension between fingers) and thereby allowing your line to untwist itself
atish.rowjee
Thanks gents. This is really helpfull. I appreciate all your help. I will try your suggestions. Thanks again. I hope this post will help other too.
