Fishing a new dam
chrisv
I have the good fortune to have moved to a farm recently that has a large dam with carp. I have seen carp and other fish (possibly bass) breaching and the farm owner has confirmed that carp is present in the dam. I have spent two very short sessions on the dam over the weekend fishing conventional but had no interest. The dam is on private property and is never fished. I measured the depth at around 3-4m at current water levels. The is a nice channel between the main bank and a small island 2m in depth with a nice drop-off to 3,5m at one end. I have detected fish movement in the area of the drop-off. I was thinking of setting up a feeding spot in that area of the channel and would appreciate any advice on how to fish an un-fished dam. Tactics etc. I'll explore the rest of the dam coming weekend using the bait boat and fish finder.
Chris
necrovis
Agree
Keep it as natural as possible. These fish has not been exposed to synthetic food. Basics will be your best weapon here, maize and as Fishpaste said, pigeon mix.
I would also not feed too much at a time, maybe 3 days before you start fishing. Fishing the drop off is a good idea, but that means that you will need to drop your bait on the right spot to where the fish will feed on that drop. I have found that when I place two lines that the one in spot produce with more rapid rates than the one out of spot.
Maize as a hook bait is a good idea, if you use that as your basic ground feed, use that maize.
Unfished farm dams can make for some of the best fishing experience. Sometimes those fish can go "bos" :)
I hope you find this dam as one of those treasures.
chrisv
Guys - Thanks for the advice. I usually buy a good bird food mix from the pet shop - when cooked it makes great feed (I often use this mix when setting up a feeding spot for specimen as well - I'll then mix in either tigers, hemp, lupine, crushed boilies, etc. to complete the mix). I never feed in huge volumes - it spoils the fun.
