Exceller Plus
Gareth88
Hi Guys,
I have the old silver Exceller plus 4000. It was a hand-me-down from my brother so I'm not actually sure how old it is.
It holds a special place in my heart as it was one of two reels that converted me to be a grinder fisherman. I've caught some really good fish on it and it has treated me well. I've looked after it in turn with fairly regular servicing from professionals. Over the past year I've had the line-roller replaced and the anti-reverse stopped working which caused the reel to wind backwards under any pressure. I got this fixed, but it just started doing it again over this past weekend.
Any ideas what the issue could be? Would it be able to be fixed properly, or do I need to accept that this reel might have run it's race?
neilg
Replace all the bearings...take them to bearing man
I also have the Exceller Plus 3000 that's many years old, all internals still original
Same types of problems as you, but I decided it's not worth it to replace all the parts (bearings, drag clicker, anti reverse). I will never get rid of it, it will stay with me as a reminder that brilliant reels don't have to cost a fortune. I will now allow it the rest it deserves.
if I take the shaft (that the spool and drag knob screws onto) I can actually move it to the sides.
Fishpaste
A word of warning:
No so long ago I was quoted ridiculous prices for bearings on my Exage 2500 from bearing man...2x small bearings at R450 EACH!!! went to another bearing place and got quoted around R180 if memory serves... In the end I found the bearings at a local tackle shop for under R20.
mrcricket
Hi Gareth,be careful of over lubrication.also an issue,if not its definitely the bearing.
My advice is,first clean the anti rev bearing and try again.
