Ever since I learned that knotting braid reduces t
Ever since I learned that knotting braid reduces the actual strength by up to 40% I've had a phobia about knotting braid and after one or two big fish lost it became worse and worse.
Continued research and test after test i can safely say the best way to join solid braids is to stitch them together.
Select a needle to match the braid you are working with. Now with a 25-30cm overlap begin the stitching.
Here is a stitching together of 2 80lbs Jerry Brown solid braids.
Stitch braid one into braid 2, in and out stitches (at least 20)In this case the green into yellow
Pull the green into the yellow and (1 into 2) and pull a tag end out.
Now reverse the process and yellow goes through green, 2 through 1.
Pull the 2 braids tight locking the stitches down and closing the connection off
although the stitch now works as a clinch connection ie. the harder you pull the tighter it locks some may feel vulnerable leaving it like this. One can then make a series of 6 half hitches to keep the braid secured (should you think it will slip)
Myself, I make 25 stitches and trim of the tag end tight against the main braids. Tested and tested and have fished with a section of braid I have stitched like this (spinning) for a long while now without it unraveling and without it slipping. in more than 50 tests we've achieved 90% plus of the stated breaking strain
supercab
Hi Gcvanheerdon
I use a normal needle the only thing is the eye must by big enough for
the braid and i just make the point of the needle a little blunt so that it can push thru and inbetween the braid strands and not to pierce the strands.
Hope you come right it really works.
sakn
When I join braids, I find it easier to make a braid stitch loop in each braid and join the loops with a cat's paw.
How would this compare with stitching the braids into each other?
Haven't tested it but believe it will be 100% as the catspaw will lock both legs in position and believe it will be massively strong and secure connection
