Electric connecting the hds sonar and strukture scan LSS- 1
gregkrak
Hello !!
I just bought sonar HDS-8 and Strukture scan LSS-1 and I have some questions about the electrical connection:
A.        Photo of power cord Structure scan LSS-1
B.        Photos of power cord sonar HDS-8
  1. Can two red lines (HDS-8 and LSS-1) I connect together to the battery ?[/*]On which wire (of sonar) to install HDS- 8  sonar  fuse ?[/*]On which wire Structure scan LSS-1 install fuse ?[/*]I read somewhere that the yellow wire scan sonar and strukture scan one should connect - whether that's true.[/*]Where install (on which wire) in LSS-1 switch ?[/*]Is it true that there are two options for connecting to the sonar HDS with Structure scan LSS-1:[/*]
-       yellow wire connects the two devices and in the moment if I turn the sonar on they are enclosing strukture scan
-       switch is mounted on the wire of strukture scan and it depends on me whether I enabled or disabled
Please for the help and the detailed description of ways podłaczenia of these two devices because I don't wish corruptions (to burn) of devices.
Thank you very much in advance for your help !!
