1.) Which pouch or shoulder bag would you recommend to carry all my lures and "stuff" that is small and convenient but good quality.
I use a moonbag with 2 side bags. 1 side for tools like scissors, pliers, penknife and sharpener. Other side is for small tupper containers with hooks, swivels, snap-swivels etc. Also keep a couple of my most used jigheads handy. In the main part of the moonbag I keep my soft plastics. I also carry a shoulder bag (sling bag) where I keep tupper containers with my plugs, spoons and jigs (bucktails). I also keep a couple of spare jigheads etc in there. This bag also houses my spool(s) if fluorocarbon that I use for leaders. You do not necessarily need “branded†bags, as you can get pretty plain bags that work just as well from a variety of shops that sells suitcases and bags and stuff (including some grocery outlets). Especially with the shoulder bag, go for something that has a soft, padded, shoulder pad, as even just a couple of plugs get heavy after a couple of hours. A backpack like Homey uses may also be useful, and probably more comfy than a shoulder bag, it depends on personal preference.
2.) What shoes do you guys wear when drop shotting (wading and on rocks etc.)
When I fish from the rocks and beach, I use a pair of hit-tec aqua-shoes that I got on special somewhere. They are light and drain well. If I am going to fish predominantly from the rocks, I use my pair of short gum-boots. They are the best and safest on rocks in my opinion, but a tad heavy for walking .long stretches on the beach. I have drilled drainage holes on the sides of the boots for water to drain out easily. I have seen that Rocky have a new shoe on the market that is a hybrid between the old well known Rocky “plakkie†design, and the “Crocks†brand shoes. I will love to test a pair of those!!!!
3.) Which brand of jig heads are known to be the best? I am thinking 1/8 and 1/4 size round jig heads? what is the biggest I can use on my 7" Tactix and 2500 Exceler?
I have to go with Homie on that one, Berkley’s jigheads are the most reliable that have used so far, and I am kind of sticking to them these days. I have tried a number of other jighead brands, but I have not been happy so far. I am thinking of designing and casting my own jigheads at some stage, using decent hooks and stuff.
4.) How do you keep your stuff dry (camera etc.) when wading and splashing through water
Zip-lock bags. They work great for me. Just keep them away from sharp objects in you fishing bag! My camera is in a marine casing (Sony).
5.) Setting of your drag. How?(basic principal)
I do this on feeling. Tight enough to make a decent strike fast (without holding onto the spoon), but loose enough so that my tippet will not part on the first run of a decent fish. From there I set my drag on feeling. I know a lot of guys do not like to do it this way, but it as been working for me.
6.) When going drop shotting for the first time, what would your approach be i.t.o identifying possible" hot spots" etc.
Again, I go on my gut feeling. Generally areas around rocky points and the adjacent beach are always worth a visit. Look for gulleys and foaming (working) water. On the beach I usually look for any part of the beach that looks a bit different than the rest, even if it is just a sandy point stretching out a meter or two further then the surroundings. Also look for rip currents where the water runs back strongly to the open ocean. Again places where the water is working up foam are worth trying. Then of course the gulley just behind the shore break, in front of a sandbank.
7.) Which 3 lures (I mean 2- Cammo worm appears to be 1) should I buy first.
In terms if soft plastics:
A. 2†Camo sandworm (although the natural sandworm also works well sometimes)
B. 4†or 6†Pearl watermelon shad (Although a darker colour is better just before dark and in dirty water)
C. Those curly tail mullets also 4 or 6†in chartreuse.
In terms of lures
A. Good old silver S-type spoon in at least 2 sizes (I would recommend a couple of different types and sizes of spoons)
B. White Bucktail jigs (Like the spro)
C. Chisel nose plug in white and white with red head (I would also keep 2 sizes)
8.) Can I drop shot low and high tide. Which is the best?
Both are good! I think time of day is more important, and again early morning late afternoon is best. High tide will often bring larger game fish to within casting range of lures. Low tide allows one to explore waters out of casting reach at high tide. Best tide is any tide that you have bait in the water.
9.) I have fished bass at competitive level. Do I apply the same retrieves as per soft plastics (mojo rig, carolina,jig heads etc.)or is it very different in the ocean. If so, please a basis to start working from.
That should work fine, as you are also targeting predatory fish, or awakening a predatory impulse in the fish. Like Homie said, try to make the lure alive, and as natural as possible. If all else fails, do whatever comes up in your gut feeling, sometimes you can irritate a fish with lockjaw to strike at an annoyance.
10.) How do you guys care for your reels and rods. I travel by plane often and have purchased a tube for my rod. I suppose the reel has to be washed with fresh water etc.
Rods get rinsed of with fresh water and allowed to dry before packing into tube. I store the rods in their tubes, with the top of the tube open as to not trap any moisture (prevents mould in the tube and rod-bag). Reels het rinsed in fresh water, and lubed from time to time. All my lures also get a rinse and are allowed to dry on a towel.... saves a couple of rands on replacement kooks
11.) I would love to catch as many species as possible. Which lure is the best all round lure to achieve this?
Camo Sandworm
12.) Can you "drop shot" in the dark
I can not see any reason why not, although I have not tried it yet. I would however go for darker to black lures at night, and also bigger lures that create a lot of water displacement and vibrations. The object here would be to get something with a good silhouette that makes a ruckus.
13.) I don't go the the ocean that often. If I purchase worms (berkley gulp) now. Will they last if sealed in their packets properly and for how long, or should I only buy before I actually go fish?
I have no Idea, but as long as they are sealed and in oil, they should be fine!
14.) What is the going rate for Berkley cammo worms and which dealers generally have the best prices on these?
Like Homie said, somewhere around R60
15.) What is the "real" difference between Berkley Gulp and Berkley Gulp Saltwater?
As far as I am concerned...same thing with different spelling. I guess the saltwater range has got more imitations of actual saltwater creatures
16.) Does the color of the jig head lead make any difference. I see some guys fishing with red ones
So far I have not picked up significant differences. A red jighead with a pearl or white trailer will probably give “blood†effect, or maybe contrast? I would guess that you can use jighead colours to your advantage under certain conditions.
17.) Has anyone caught dangerous species (devil firefish etc.) on the drop shot and which ones?
I do not know of any-one
18.) For shad: which lure is best and how will the set up look i.t.o leader to wire to lure.
For shad, go with a spoon. They destroy soft baits, and if you hit a school of shad, I would not suggest feeding them soft baits. I have gotten away a lot in terms of using a spoon without adding steel trace. I guess that it has got to do with the fact that shad attacks the tail first.
19.) Do you always fix the leader directly to the lure or do you guys also make use of quick change snap links etc.
I like using a snap link due to its ease, and the fact that I like to try a couple of different things every time I change spots. My gut feeling however is that you would probably up your strike rate by taking the time to tie directly onto the line with a rapala knot. That is one of the reasons why I started using a tippet as well, and I do sometimes refrain from a snap-link if I use the smaller soft plastics.
(20)! Where can I find the best information on fishing with lures in the sea?
Ah, that one is easy....right here on SEALINE!!!
