Howzit.
There are currently quite a few shad around and since they don't show any signs of moving off you should be in for some decent fishing.
Firstly, I would suggest that when you arrive you add a few spoons to your arsenal as the shad will simply make mince meat out of your soft plastics. I would suggest getting some Kingfisher Ondas, and Iron Candies that match the casting weight of your rod. Also look at some plains silver bullet and s-bend spoons.
With the shorter rod you're going to be using I imagine you'll be able to get enough distance for shad since they literally feed in the shore break.
Regarding beach marks etc, I've been having a good amount of luck fishing Durban View, which is in Umhlanga. It's very easy to find being just south of the Lighthouse. It's very safe there as far as beaches go, with good parking for your cars right at the access. The lighthouse is also a nice place to spin for small kingfish and shad, I'm just not sure about the distance you'll get with the 7ft rod because it's very rocky at the lighthouse. They have also recently renovated and reopened Virginia Beach, and you are allowed to fish off the new stormwater pier that they've built there.
Best times for shad will be very early in the morning. I fish most morning before work, I arrive at the beach at 4AM and spin until around 6AM. This morning I got three shad at around 5AM.
If you need any other help just let us know.
