DUO TIDE MINNOWS
Ben REINERS
I saw these Duo Tide Minnows for the first time yesterday & immediately thought of the RAPALA Max Rap17 & smaller versions.
I don’t know how many anglers has seen these yet , though was a first for me as I say, & posting it for interest of the lure junkies ::S
These lures should do the trick just as good as the Max Rap, even though the Rapalas vary in price range from R170 to R220 at some shops.
Its Japanese made, nl Duo Tide Minnow, cost slightly more than the Max Raps in SA , & has rattler weights.
For casting the weights move to the back when you load your rod for the cast, thus giving the extra weight for distance casting & on the retrieve the weights shift from the rear to the front & depending on you retrieving or pausing the lure.
The cost in SA is roughly R250 (Durban shops) & on Ebay anything from R170 to R190 excluding postage of about R40 to R60. So if one orders more than 2 or more, it could be worth while the price.
They come in Floating & sinking from 120 to 175mm & in an array of colors.
Have a look at the full range at    http://www.tacklejp.com/DuoTideMinnow.aspx
die spook
Baie mooi, maar hel dis vrek duur! Vroulief wil klaar my gatvelle aftrek oor my cheapie lures wat ek versamel...
Ben REINERS
@j-Bay - I saw from 17 - 27g. I don't know the exact weight of the Max Rap , but the Jap lure feels slightly heavier.
Ben REINERS
@ Spook - Wel my vriend as jy n vis kan uit oorle met n lure dan kan n mens ook probeer om die wederhelfte te uit oorle of te oorreed tov die lures !!
Ek het n vriend (nou geskei - nie agv die vis tackle nie ::S) wat voordat hy by sy huis aan kom & te verhoed dat sy vrou sy nuut-gevonde speelgoed ontdek ,dan pak hy sy tackle onder in die onbelangrike pakkies waarmee hy huistoe gaan, soos , die groente, skoonmaak middels, ens & smokkel sy nuwe stokke deur die dag in na sy mortorhuis terwyl vroulief by die werk is.
Sy vrou sien niks & hy het geglo , dat hoe minder sy weet maak die hart nie seer nie. As sy in sy motorhuis in gaan & nuwe stokke & katrolle sien & uit vra, dan was sy antwoord altyd eenvoudig - "oh , daai stok , nee dit is n ou stok" of "nee ek het hom al lank" of "nee dis nie myne nie , dis Dirk sin , hy het dit vir my geleen"
Als was in goeie humor gedoen met geen bad intentions nie & ons het hom vrot gespot as hy by n tackle shop inloop & hy kry daai "stiptelike kyk" uitdrukking in sy oe soos iemand wat  hom  in zoom op n goeie koop !!
So ja, ek dink daar kan goeie verhale (verskonings/redes) uitkom vd SEALINE manne wat hulle al gebruik het om verby die "regering" te kom.  :fbash
coop
17cm maxrap weeg 28 gram maar nog steeds aan die ligte kant vir n lekker gooi aasvan die kant af........
pampoen26
These lures are quite popular over here in the UK for bass. Casts really well but need a fairly light rod. We fish them in sizes from 75mm - 200mm Here is a link for those interested,
http://www.mrfishjersey.com/lures/shallow-diving-lures/duo.html
Ben REINERS
@ Pampoen - Thks for the info.
Quality lures does not come cheap , but I think at times the market has gone ridiculous with pricing on certain items at stages, especially Jap made lures. If you buy one , then you almost feel sorry to use or loose it, & will take a cold swim should it get stuck in a dam , but in the salt you have zero chance , so you end up buying 2 !! Aai !!:fbash
smiley6996
I have a lure like that I am always to scared to use it but it never fails me. If it had to get stuck I would probably drown before I lose it my first rapala I bought more then 10 years old already
xtc
the duo tide minnow, surf, 150mm, is 29g - not sure of the others - just have the one, neo pearl (white)- got mine from Rolfe but cannot remember the price
