drying bench for poppers
tackle whore
made this the other day to dry poppers once epoxy coated . runs off a microwave oven turn table motor about 5 turns a min. can be adjusted to any  popper lengh .
tauruck
Mark, Go LARGE or go home.
If you're into mass production this is the only way to go.::S
tauruck
That's lekker. Do you through wire after or are the hook loops hidden?
tackle whore
through wire after - once dry cant see the whole in belly for the swivel , i pour epoxy down centre as well, with smaller poppers submerge whole thing in epoxy then spin to dry gets a good seal inside and out .you be amazed that most of the top jap brands dont think to pour epoxy down the centre hole only seal the outside .were you find the film reels ?? your age showing ::S::S::S
Tauruck,
A bit much for the average bloke!
Yo TW, Me likes that idea. I'm going to make one the same but with hooks and springs so I can cast my lures with the wires and attache them with the springs. Very good man!
tauruck
Bennie, You must have some spools from Mig wire around your factory.
I'm thinking if you part them off down the centre of the hub you can get two out of each one.
I do,
But I'm not into mass production of lures, so the simple one would be fine!
Do you want me to keep some for you? I come up to Joes often and can bring them for you. Can even part them for you if you like.
Bennie
tauruck
I do,
Bennie
THanks man. That would be great.
I threw all mine away and now there's a need.
