Dropshot Tackle Question
wackwack
Hi Guys,
I fish maybe once or twice a year so im not very serious. This drop shot thing looks cool, so i'm wanting to get me some tackle before I go away to the coast for Dec.
I'm going to Morgans Bay (ECape) it has a river mouth, lagoon, etc. Without getting ripped off at the fishing shop, what type of rod (length, weight,etc) should I get & also what types of lures to catch fish (I'm not fussy at to specific types). Hopefully I could eat one or 2.
Please  excuse my ignorance. :wfish
Thanks in advance
Predator_828
Hey, I would recommend a 6 - 8ft graphite rod (Shimano Vengeance is a nice one)
For a reel I would go with a shimano exage 2500 perfect for dropshot if not then a Daiwa: (Crossfire, regal or procaster) 2500 model will suffice.
Some braid will then be needed. Suffix braids work well and are cheaper than most other brands. 10 - 15lb braid should be perfect (with at least a 0.22 diameter) I use suffix gyro 0.17mm (15lb) braid. I got 250m for R169 @ sportsmans warehouse.
Then that's your base tackle done - This setup will last you many years and will perform perfectly for riverlagoon - you could even use it for the surf.
Then the lures. Here's the basic stuff you will need.
• A few packets of Mcarthy Saltwater Baits (V-tails and paddle tails 4 or 5 inch) Try the Plain Yellow, Elf and pearl white colours.
• Some berkley camo worms are also nice to have in your box.
• 3 or 4 strike-pro thai sticks. Plain white and red head work nicely but it doesn't really matter.
• Finally a few spoons and plugs.
• EDIT: Bucktail jigs are also a must have!!!
Additional tackle will consist of Flurocarbon for leaders, Power Swivels and a few quick snap clips for frequent lure changes. A bag to carry this around helps. Also don't forget Jigheads
Good luck mate, have an awesome time...
wackwack
Thanks a mil for the reply...
What do you reckon all that will cost me?
I'm starting it think I should rather just fish in the surf (old school - rod, reel & sard)
PatrickC
I'd recommend a small shimano reel like the solstace also in about 2500 or 3000. The 7ft shimano scimitar rod will also pair nicely for the type of fishing you want to do. For the both of these you looking at around 700 for the pair and then another 200 to 400 bucks for braid depending on which type. Also using suffix and am quite happy with it. EZ braid is also not to bad and is reasonably priced but fades quite quickly.
Thats the cheap part! Once you get started on buying plastics its to easy to be the one being caught.
If fish light tackle and rock and surf. Can't say I enjoy one more than the other but nothing beats the thrill of a leerie boiling behind your popper and watching them smash any topwater lure!
BoomBoom
For someone who does not fish often , I would recommend a 9ft rod ( shimano vengance is well priced ) paired with a 4000 shimano Sienna ( around R350 bucks ) . Maybe with the suffix fuse braid ( fine for a beginner & cheap ) or just stick with Mono line if you more comfortable( at least pack a spool of 300m of 12lb - 15lb mono in case you have wind knott issues)
Reason i say 9ft is you will cast a bit further - and often on that coast distance can be the difference when trying to reach areas where fish hold .
That combo would probably be about R850 my guess? maybe less.
Then for that area especially spinning in the Mouth you just have to have McArthy Paddle tails 5inch and Alcocks Double slim spoons and a few Predator Plugs 1oz & 1.5oz
Match your paddle tails with 1oz & 1.5oz jigheads. Remember you will lose lures so have enough for your trip ! Depends how much time you gonna spend spinning.
these lure are easy to use it just comes down to your retrieve speed .
You wont go wrong !
Good luck
wackwack
Being a typical scotsman...and not fishing very often, I'm trying to get the most out of this rod & reel.
Would I be able to use the rod & reel for bass fishing?
BoomBoom
Unfortunately it would be a terrible match for bass fishing ! Too long to work your your finesse worms and minows etc in my opinion !
you would get away with the reel , but not the rod !
When you get into your fishing you will see that there is a reason for each type of rod , reel and lures .
But for cob , elf and leeries where you going 8ft - 9ft would be ideal !
BoomBoom
wackwack wrote:
I see mias is selling a Shimano Hyperloop 6000FB for R199.
Would this work?
bit big and heavy in weight ! but it will do the job ! still think a 4000 size reel is a better match for 9ft rod both in weight and balance
But your budget determines your purchase !  Sienna 4000 probably 150 -200 more
