i want to try target steenies in the surf, whats the best size camo worm and best sized jig head? Also what type of retreive is best suited?should you vary it? is an 8 foot rod big enough? thanx guys...
I would also like to know. Where I live, I see the guys with 10 ft poles spinning for yellowtail as they are far out. They use penn reels not coffee grinders and "gut" not braid. Yet they cast far??
I have asked this before but the thread changes to who has the best rig and not any advice.
Can I cast as far with a good 8ft rod and a good Daiwa reel with braid as these guys with heavy stuff?
I have been drop shot fishing for a year or so and in the beginning I also thought the same jeez other okes are throwing huge distances and I can't but I soon learnt that fishing drop shot is not about distance or depth it's about patience and reading the water / situation your are fishing in.
I have a 8ft heavy Exceller with 8lb Fireline and I can cast 80 - 90mtr with a 3/4 jighead and 5" jerkshad. The next thing dropshot will teach you is just how close in the fish are feeding. How often is a lure taken half way through the retrieve ie. 40 - 50mtr out? Try a 1/2oz jighead with a 6" Camo worm and see what happens. You might battle to find heavy jigheads with a small hook and thin bait keep section. With the camo worm you want the lightest jighead that can get out far enough and stay on the bottom in the wash.
with plastic chisel nose plugs im sure you could cast as the guys with heavy stuff.4 steenies try the 2.5 inch peeler crab in natural and like Fluke said the 6incgh camo worm rigged hole.the retrieve should be slow twiches along the bottom.
