drop shot technique - USA
DropNut
I tried it, unsuccessfully though, but I dont like this cause rigging the hook directly to your leader in this type of manner will reduce the amount of action that your minnow will have. Also from exerience I can say that this trace is similar to the type that you will use in freshwater, so I think that this rig was made for freshwater.
Nepptune
Guys, I'm not gonna get into this, but the technique in that link IS dropshotting.... Its been around forever!! Both in the US, and other places.... Why the hell the folks in this country decided to suddenly use the term "Dropshot" and suddenly bring this"new" form of angling to this country I will never know... its ridiculous and a marketting ploy!!!
Its light tackle artlure fishing, its been around forever...
Guys
This is exactly what us freshwater Bass fishermen and women were saying all along, this is Dropshotting and the techniques that are applied by the saltwater guys and gals which is reffered to as dropshotting is in actual fact technical speaking called Jigging as you use a jighead and not like the weights in the link that actually drops when it gets snagged up, which relates to the name Drop-shot.
But as the tackle shops have the monopoly when it comes to fancy naming of products and techiques to increase their sales have called the jigging in the salt Dropshot and whooooooo now there's something new, it's not new because it's jigging and it's just like Nepp's said, jigging has been around for eons, thus the confussion sets in, call it what it is and away the confussion will go, jigging is well jigging and dropshotting is well dropshotting and they're not the same although you might be able to jig a dropshot rig you can't drop your shot on a jigging rig cause then there's no rig (Hook and weight).......
Just the reality and worth the 2cents if you care to be politically/fishingly speaking correct.
Just have a look at a section of the article and do some low level analysis and you'll see what this poor sod has been trying to say:
"Drop shotting plastics in the surf is not an everyday technique. In most situations, when the beach is relatively flat and there is surf and surge to contend with, a carolina rig, leadhead or spoon will be more effective. But it’s a good technique to keep in mind when you stumble on that deep hole and other techniques just aren’t working. Try the drop shot and you just may pull out that big ole halibut you just knew was lurking in there.
See there's a difference, easy as pie!!!
:f1shy
