DROP SHOT KNOW HOW
waterdog
Hi Gents,
Im new to the site and it looks great! Time to put it to the test.
I have finally organised a trip to Kosi Bay, we staying in the community camp Kwadephe.
We will be mainly drop shotting and flyfishing and occationally throwing a little pap(live bait)! Be will be fishing from a boat
I would like to target kingies and rock salmon any anyting else dumb enough to attach itself to the end of my line
Can anyone help with -
Goods spots?
Which lake is best?
What lures?
And what does a Berkley Camo worm look like as it seem to be in all the forums?
Thanks guys any help will be great!!
Andre
carcharias
Hi waterdog .
Welcome to Sealine
Read the light tackle art angling articles done by Nielg. This stuff should be published in book form. Probly the best info on the subject you will find anywhere.
camstaude
Third that.
There is so much info on this topic.  Search all the articles by neilg G.
camstaude
Third that.
camstaude
Third that.
Dingleberry
Howzit Waterdog. I can't remember if that is the name of the camping site at the gate to the mouth or not. If it is, you're at a prime spot. Pity they only open the gate at 6:00 am. Nonetheless, the mouth should provide you with some fun. I am not sure if the GT's are inshore yet but there definitely will be other species of kingfish to target. The name of the game here is to cover good water. Casting line (Fireline) of 20lb should suffice and leaders between 20 & 50 lb should do. I would suggest jigheads from 1/4 ounceto 1 ounce. Plastics can be quite big. 4" and up. Obviously I would also take some of the smaller stuff 'cause I always take too much! Chartreuse and white are good colours. I wouldn't bother with worm. Also consider taking some small spoons, surface lures and a Halco max or 10.
I would concentrate on the seaward side at the mouth and Banga neck. There are some exposed rocks just off the mouth and a good wade might be necessary to get a bit closer. Take a PFD/lifevest of sorts. Also bear in mind the Zambies. You would need to approach the Parks Board for info as to where one is allowed to fish south of the mouth as there is a system of beacons to mark the boundaries. Be aware that the Mozambique border lies just to the north and you might pick up trouble if you cross it unknowingly.
You can expect to encounter many 3 spot pompano (1/8 ounce 1/0 and 3" minnows for them) and some bastard mullet. Target these just behind the shorebreak - I mean this literally. The best bet is to wade in at a likely looking gulley and cast into it parallel to the shore. Casting from the shore into rips also produces. Halco streakers and other small spoons will also work for both these.
waterdog
Thanks Dropshot guy, Those worms are EXPENSIVE !! i have been quoted R250..  I hope they work as well as everybody recons
Dingleberry! thanks for the advice that sounds good.. Getting me motivated.
Shimaiwa
Believe me the worms work and the tub is actually very good value for money, it is packed full. Here in Durbs most shops are around R200. Be sure to transfer the lures from their original packaging to a screw top bottle (see the pic) as the tub leaks out the sides.
