Silent Bob
does a thinner line diameter improve distance?
Read our discussion on braid under the multiplier casting thread. Braid is the perfect thin strong line!
50 to 100m should be fine for most edibles sometimes even closer! .45mm line from the beach should easily get you past 100m,the reason I sometimes use a thinner line like .35mm/.37mm is for my lighter reels and the line also has less drag when fishing in wind or currents...my 2c.so whats a good distance for an average fisherman targeting ed?
what size reel is considered light? my new reel is a size 30. should i be concerned that a thinner line means a light weight? e.g. 0.50 is rated for 15kg, 0.40 is rated for 10kg, etc.[color="#006600"]Silent Bob[/color] wrote:50 to 100m should be fine for most edibles sometimes even closer! .45mm line from the beach should easily get you past 100m,the reason I sometimes use a thinner line like .35mm/.37mm is for my lighter reels and the line also has less drag when fishing in wind or currents...my 2c.so whats a good distance for an average fisherman targeting ed?
On my Sl 50.. I use 300 m 0.45mm & 300 top shot 0.4 mm .
So i only change 300 m line at a time .. i dont makeany joins less than 150m from top cos a knot once cut my thumb deep ...
