DM craft upgrade
toli
Hi All,
I have a Dm craft baitboat,still got the old big black and super slow motor in.
Want to do an upgrade,want x3 times the current speed preferably on a brushed motor.
anybody done this upgrade,and what motor are you currently running, seen the stuff on loukie baitboats, but dont think the RPM is good enought for the speed im looking for, seen a guy with the 360camo, the motor was a pink outrunner and man oh man, that is in the line i was thinking of(or even half the speed would be fine).
anyone that did this before,please share and a pic or two would also help.
((s((peed)
andriesyssel
I am sure the camo uses a brushless system, that's the only way you will get those speeds. I owned a carp king and changed to one of loukies boats. Very happy with it. More stable in choppy water and faster. Brushless will be expensive to repair. Quality batteries are expensive to. It's not always worth upgrading a boat. If you have the money just buy the one you like.
toli
Hi Andries, that the exact reason I want to stay away from a Brushed motor,the cost involved.
And buying another baitboat is not an option,as I just had to twist the misses arm to agree the the current one.
There is a motor brushed with the following specs;
12VDC 5.6A 7630RPM ST10.57KG.CM for amount of R351.48
that im considering(i know i wont get nearly close to a brushless system with this).
But what im wanting to know is, if this will make a big or very small difference to the boat speed compared to current motor.(think its 2800RPM)
or will the differance not be worth tho money spent?
andriesyssel
The motor in my boat runs 4800 rpm and draws 1.4 amps, 75mm prop. I am using a speed controller for it. The motor you want to use will kill a 7.2 amp battery. It's all about the money. I will suggest you buy the motor and prop from loukie. You will run at double the speed you are now, and the battery lasts longer.
flare02
Hi toli
See you wanting to upgrade your bait boat and youre in the centurion area. You should contact Tackle2Go they do almost everything with bait boats. The workmanship is impressive just as is the service and advice.
I have seen several of the projects(some very scary looking) they have taken on and from the before and after its really amazing to see. A few friends and myself have had our bait boats upgraded by them and no issues since.
Some of the stuff Loukie offers now was being done for years by them, like the dual battery system, the 12v-6v conversion and the list goes on.
Gideon
Tackle2Go
Telephone: 083 258 6913
the link contains a few pics of restore work
http://tackle2go.co.za/bait-boat-repairs-restorations-and-spares/
toli
Thanks flare, that will help.
will contact him for a motor.
see he has a sling for a 12v battery and converted the remote, that was my next step after completing the motor transplant.
It does really help to find someone working on the boats(or selling parts) close to home.
thanks
toli
Bought a new shaft(longer)
a New 75mm prop and rudder from Loukie.
boat is already doing twice the speed it was before,the correct and proper parts make such a BIG difference.
Next month will upgrade the motor to the 4800rpm 1.4a
