Buffalo Hunter
In Australlia, fishing for Blackfish( Girella Tricuspidata) is seen as an ancient art practiced by cranky the old ballies. This is a load of rubbish as you don't have to be an old ballie to become a "gun" Blackfisherman.
In fact it is actually quite an unusual method of catching this herbivorous species. the bait of choice is sea weed or sea cabbage ( both Algae) that grows in the intertidal zone. The gear is basically a soft medium taper rod of 12ft fished under a float with 2 to 3 KG line. They grow to an average size of 1 to 1.5 Kg and give you a great fight when hooked.
Fishing the ocean rocks can be hazardous so you have to wear cleats on your sand shoes to give you grip on the rocks or wear the spiked rock boots.
I believe that you could catch both Galjoen and Hottentot using this method of fishing. Look in the entrails of the next Galjoen or Hottie that you catch and you will notice quite a bit of weed inside their guts. So why not give it a try when the water is too calm to fish with the normal baits.
Can you give more information on the materials you have used?
