Coleman Cooler Box with Cutting Board
A.R
Hi All, just an idea for anyone who has one of these.
I normally use my Coleman's Personal 8 Cooler box for my bait as it keeps it frozen for a long time and due to its construction does not get damaged on the rocks.
The only down fall of this was that there was no cutting board, which meant I had to always carry a separate one around. The separate cutting board would get covered with sand when fishing from the beach and was too unstable when preparing bait (balancing) on the uneven rocks.
So I decided to fix my own cutting board to the lid, same as the safaris and pacific's.
The lid of the cooler box is profiled as such, so that when turned up side down, it sits into the open cooler box perfectly stable and serves as a drink holder.
All I did was cut a piece of cutting board to the required size (to fit the underside of the lid and fit inside the cooler box when closed) and fixed it to the lid with Heavy duty Velcro.
Now all the left over oils and blood from the bait remains on the inside of the box when its time to go, so its a lot cleaner as the top of the lid is spotless and the velcro allows you to remove the cutting board to wash it when you get home, and simply stick it back on for the next session. The Velcro also gives the board some spring, which means that you wont damage your cooler when beating chokka.
Some Pics Below..
fishfinder23
nice idea!and helluva lot cheaper then the safari's!im def gona go get a colemen this week..transkei trip coming up!cheers :)
Psy
bloody good idea mate, also you can keep your defrosting bait in the air gap below the cutting board.
Shot-a-lot.
Trophy
Hiya A.R.
I use the same cooler, have for the past 8 years.
Works well...dare I say it better than a Safari!!
I'll get a pic off and post it soon.
Regards,
T
Homie
Hahahaha ! Pity though, it only takes 6 beers LOL.
On that topic, why dont we guys use coleman boxes ???
A.R
Ya, I also don't know why Safaris are the preferred choice. On the rocks the coleman doesn't chip at all, in mind it would last a lot longer.
I just need a bigger one, as this one is a bit small for carrying big frozen baits for sliding (including your ice packs).
Trophy, yours looks like the next size up, how many litres is it?
Andre Laas
You can even up the insulation properties of these coolers by filling the air-space  between the inside and outside walls with expanding foam. I am sure that when empty, it will still be lighter than an empty Safari chiller
Sailfish
Nice cooler thow. Think if you can make the cutting board hinge, you can use the lid cavety for storing knife,tjokka hamer and cotten thow. Thanks for the photo,s A.R.
