Coffee Grinder
Spesbona
Hi I need some advice, I have a problem with my left wrist and have a problem when casting my Multiplier. Would like to know if there is any coffee grinder that I can be looking at to replace my Saltist ( until my wrist is better), line capacity is important would still like to catch with quite heavy line? Any suggestion? Thanks
Nippy
Hi, what size of saltist do you have. Line capacity required. Daiwa BG60 is a good reel. Line capacity ? I think you get a BG90 if not mistaken. The saltiga surf coffee, might need to break the bank though. You can fish straight braid, costly.
[align=left]SASURF6000
-/XH (Action)
4CRBB,3BB, 1RB (Bearings)
3.6:1 (Ratio)
18.70 oz (Weight)[/align]
[align=left]Line Capacity
25/280, 30/230, 40/170 (Mono)
BRAID: 15/1350, 20/1130, 30/730
 [/align]
Check out http://www.daiwa.com
Link http://www.daiwa.com/Reel/spinning.aspx
Maestro
are you using a rod with a trigger butt? If not,perhaps it would be a better option rather than investing in a new reel, simply because 1.the trigger butt putts less strain on your wrist 2. Using a coffee grinder will not drastically reduce the strain on your left wrist....or maybe you should just take a break until the wrist heals instead of risking further injury,be it even with a coffee grinder.
Spesbona
Thanks Maestro / Nippy
Maestro it is more the thumb joint than the wrist itself so I believe the coffee grinder will put less stress on the thumb joint than the multiplier when casting the rest of my wrist is fine.
Nippy had a look very interesting, can you put mainly casting braid on it for more capacity?
Regards
Maestro
No prob,well if you r looking at the BGdaiwa grinder, i personaly have 1 and its a great, tough reel..but a bit bulky for surf casting,more suited for paddle ski and off shore,although if you want better casting distance and you r willing to pay the high price, then the new daiwas are a better bet..otherwise shimanos range are also good and more economical(visit GANIS in witbank as he's shimano pricing is the best that i'v found)...dnt be shy to check out the new okuma grinders as they r v highly rated and excellent,economical reels...best of luck
