Choosing a fish finder made simple Part 2
jpet
How To Pick Out A Quality Fishfinder
  1. Step 1
Understand fishfinder basics.
A fishfinder is a great advantage as it gives you an underwater view of not only the probable fish within the area, but also the landscape. It will pick up shorelines, rocks and other inconsistencies along with water temperature and depth. This will allow you to fish according to the information you are given.
  1. Step 2
Consider the screen resolution
 You can get on-screen resolution as high end as you want. For example, there are fishfinders that offer high-detail color screens, and there are also fishfinders that offer a basic 240 by 240 black-and-white lower-resolution screen. Of course, the more advanced the screen, the higher the price.
  1. Step 3
Know what wattage you need
 Wattage is one area that should be heavily considered. The manufacturers give each fishfinder a wattage rating. The importance of this rating is that the higher the wattage, the more overall power your fishfinder will have. This basically means that if you are going to be fishing in deeper spots, you will need to get a fishfinder with a higher wattage.
  1. Step 4
Consider the transducer quality
 The transducer sends out the sonar reading in fishfinders. Manufacturers call the spectrum of this reading the cone angle. For the most part, depth finders come well equipped with a good transducer. However, this is a part that can easily be upgraded later.
  1. Step 5
Look at additional features
 Some fishfinders offer a build-in speed reading mechanism. This is most useful for people who do a lot of trolling, as it will allow them to measure their speed and adjust for different conditions. Also, some offer a GPS-rendering unit that can tell you your exact position on a lake.
  1. Step 6
Consider where you will be using the fishfinder
 Most manufacturers offer portable models of their fishfinder range. A portable unit comes with a protective fold-away casing and battery pack will allow you to use your fishfinder for shore fishing. They also feature a suction cup mount for the transducer, allowing you to remove it from the bottom of your boat when using it elsewhere. Non-portable or boat-mounting fishfinders are designed to be mounted to your boat and stay there.
  1. Step 7
Know your price range
Fishfinders are much like any other electronic device or gadget. They range from budget units to high-end. Depending on your current personal budget, decide what fishfinders you should look at purchasing.
  1. Step 8
Decide to go with a certain brand
 For the most part, Lowrance, Hummingbird, Eagle and Cabelas brands have all been proven to be reputable and traditional fishfinder manufacturers. Consider your own preference for looks, styling, screen size and button layout.
  1. Step 9
Narrow down a certain model
 This is where you are going to narrow down the tech specs. Many times, different models will be priced similarly but will allow you to give or sacrifice certain features for others. Select a model that has features that will be most useful to you when you go fishing.
  1. Step 10
Decide where to shop
 Any local sporting goods store should have a selection of fishfinders readily available. However, shopping online might be your best bet. This will give you a much wider selection to choose from, along with lowest possible price.
Bingo
Any of the Big names propperly set up should do the job. My Garmin 298 Chartplotter combo does the job just fine.
Rgds   :fishn
It is amaizing how you have a good finder and you are very happy. Then you fit something like the Lowrance HDS and you suddenly go WOW! Because you now see stuff you have never seen before!
