Chicken Liver Bait Presentation
atish.rowjee
Skuimkop wrote:
Here is a method I use to make small baits 'bigger'. It works well for baits such as chicken liver, chicken hearts, chicken giblets, day old chicks etc.
If you are interested how I make it I can post more photo's to demonstrate it better.
Yes, please demonstrate and show us pics... Thanks
Alex123
That will be great, post some pics please!
Are you going to plan another "baber clinic" or something of the sorts again later this year?
::S
Skuimkop
::S
If there is a interest I will strongly consider it and it will be better organized this time around, lol.
Skuimkop
Right guys here goes. I use exactly the same method as I use to make cluster baits for specie Carp and unfortunately I only have demonstrating photo's of the Carp cluster but I'm sure you will get the idea how to make the Cat 'cluster'. I'm just going to copy and paste the Carp cluster on my data base and will add some tips and extra info at the end for the Cat 'cluster'
Here is the end result but I pulled it open a bit so you can see the tube in side the cluster.
Skuimkop
Eerstens gaan jy al die tools nodig he wat jy anyway sou nodig gehad het om 'n hair rig te maak.
You only replace the maize and tigers with your preferred Cat bait like chicken hearts in my photo above.
Skuimkop
Jy maak dan 'n 'lussie knoop' om 'n cummy stop wat sal dien as die cluster stop. Ek het met die mielie cluster sommer 'n mielie gebruik in plek van die gummy stop wat ook lekker werk.
You can replace the gummy stop with another hook that is smaller than your main hook so that you cover both ends of your bait. You can not really do this with the Carp cluster.
Skuimkop
Jy trek dan die braid deur 'n stukkie rig tubing wat jy die lengte van bepaal het vooraf sodat die cummy stop tot teen die opening van die rig tubing gaan rus.
The eye of your second hook will come to rest at the opening of the rig tubing. Rig tubing is not really stiff enough so you can use something stiffer like those micro irrigation tubing/pipes.
Skuimkop
Jy ruig dan jou baits (Tigers en mielies in die geval) met jou bait needle deur sodat dit by die lengte van die rig tubing sal pas en dan ruig jy weer die los end van die braid weer deur die rig tubing.
Remember to replace the tigers and maize with your preferred Cat bait.
Skuimkop
Jy herhaal nou maar net die proses tot jou cluster vir jou 'vol' genoeg is en dan trek jy net nog 'n gummy stop oor die los punt braid om jou cluster in plek te hou vir jou hoek wat volgende sal volg.
Skuimkop
Nou kan jy jou cluster klaar maak deur jou hoek vas te maak. Die eind produk gaan dan so lyk:
Skuimkop
Hier is die mielie cluster:
Just for your guys to see how the maize Carp cluster looks.
Ant86
Season will be finished  before we know, Riaan you are a big fan of catching big ones in April . How about a mini-social at say Roodeplaat or somewhere on the Vaal Dam in April ? I would be very keen
Skuimkop
Ok lets see if there is an interst, I'll start a new post.
