catapult
Ninja-Nic
You could try making one. I made one from resistance bands from sportsmans warehouse (about R100) and used thick blue pvc pipe for a frame.
Cool thing about these bands is that they come in about 3 or 4 different thicknesses/ resistances so you can make some mad weapons if you really want to. Ive found the 30lb bands work best for heavy ammo like 1oz lead or ball bearings.
Simply trace your pattern onto the pvc and drill a bunch of holes along your outline. Then you push the frame out, drill a hole in each fork and jam a 6mm bolt into it. Then you just wet the bolts so the latex can grip, and slide it on. You can put cable-ties around the tubes to make a more secure attachment.
Shot quite a few 1oz through coffee tins & thick plywood, and marbles fly pretty far and hard too. Will try post a pic after work.
Got a lot of plans and ideas from these sites:
http://slingshotforum.com/
http://slingshotchannel.blogspot.com/
dubs
hi ninja
was planning on shooting a few pellets app 5 meters,
interresting to try and make up one.
word of caution: there is a clip on youtube with a guy shooting 20 mm bb at a champaigne bottle. it rebounded and made a seerious hole in his head. pls be carefull
Ninja-Nic
dubs wrote:
hi ninja
Always safety first man! Always wear goggles and gloves etc. I've made everything from slingbows to crossbows, catapults even panas which launch a dart. Good fun.
