My apologies are in reference with this post
http://www.sealine.co.za/view_topic.php?id=57299&forum_id=10&page=2
The reel we used and cast was an unmarked - Squall and not the Torque
The reel has the capacity of the Shimano 50 is fitted with the same Drag system as the equivalent Penn International reel, ie duocore brakes which is the same as those used on the F1 Fighter Jet.
Hennie Papenfuss while testing the lever drag made casts of 150m and is personally massively impressed with the reel. They had them at the trade show today and to fish 0.60mm you'd have to set the drag at max 60% of capacity or you'll pop the line time after time.
I'll be getting a pic or 2 from Beyond Fishing to put it up on the system as the reel isn't on the Penn site.
Graphite frame with stainless foot, brace on the top of spool that is not in the way with casting, disengages completely for a smooth free spinning machined alu spool with rings to indicate line left on your spool.
Same capacity as Shimano 50 series reels and a drag way heavier than your regulation tackle could handle.
Retail - - Around R1700
