Camping Light
Optimus
Here is some pics of a camping light that will not cost you a arm and a leg.
Now a short description and pic of the components, where to get them.
I know it works great I got one too.
Optimus
The bulb can be bought from the China shop down the road at approx R70 and you need a box of 250 mm x 150 mm x 100 mm. The bedlamp switch and bulbholder can be bought at any hardware shop together with 300mm Dualcore(flex). The battery is a normal acid free batter and cost about R120. Connect everything and you can go fishing
wetfrog
Why not use a 12v energy saver light instead of the 220v one, it will save you using the inverter. The 12v energy savers cost +- R40 and give off enough light,and uses verry little curent.
Riaandl
Optimus normal 12V caravan Lamp complete cost about R100.00, pair of crocodile clamps R15.00 and off you go
mudcrab
@ Wetfrog,check the pic,its a 12 volt compact lamp.(all flourescent lamps are gas discharge lamps and require a high voltage to ionise the gas for them to operate,even the 12 volt ones have a invertor/oscillator circuit built into the base of the lamp.)
Speedmaster
Something that works great is those Lesuire Quipt Fluorescent lights bought at Brights and a lead acid battery teken out of a UPS. Cost is about R40
