Bucktail lures
Ringo
Hey guys i read all about the bucktail lures on sealine and was a bit skeptical on using them. Coz the retrieve differs from normal lures. But damn did they give results.
I got 4 Garrick about 74 - 88 cm yesterday and 2 skipjack during the day at night time just after about 8:30 i got a small cob. this lure is great. And really work's when nothing ells does. Highly recommended. Has any one tried it for kingies?
ziggy
how do you use it? on the bottom - bouncing? fast retrieve? I tried one the other day but was a bit confused as to how excatly to retireve it.
I was catching little kingies on a small silver sppon 2 weekends ago and got bored with that and thought to change to the jig - but no luck
Le me know how to use please
Dingleberry
Yup, caught Kingies, Cuda, Rockcod, Snapper, Barracuda and.... a sand soldier - can you believe it?! Nice catches there mate. I also had no confidence in them but I had caught so many fish during the day (all of the same size) that I thought I had might as well give it a bash. Well, after catching bigger specimens of the same species and then one outstanding catch, I was sold! The best thing is that they are so durable, cheap and you can make them yourself.
ziggy
 But how do you use them effectively? Where do you cast (foamies, backline, rocks, sand etc etc) and how do you retrieve them - fast or slow, on the bottom?
Ringo
http://www.youtube.com/watch?v=C_MashqxbhM
have a look at this.
i give it a meduim retrieve and a few jerks (3) every 3 tirns with the reel
Ringo
also for leerie and skip jack dont let it hit the bottom.and like nepptune would tell you for cob it should hit the bottom hard.
You can thank nepptune for that tip.
Dingleberry
Hi Ziggy. Ringo can correct me, but I would assume from flyfishing experience that for skipjack/springer that a slowish , just-below-surface retrieve would be required. Consider keeping your left index finger extended to bump the line during the retrieve for action. Obviously, a lighter jig would be used (1/16 to 1/8, depending on current/wind) so that the jig wouldn't sink too deep. For Kingfish and I presume Garrick, a quicker, more violent jigging action could be employed, along with a heavier jig. Try raising the rod tip in a smooth action from horizontal to the ten-o'clock position and then whipping to the vertical twice. Then tighten the line, let the jig sink a bit and repeat. I also find keeping the rod horizontal and perpendicular to the direction of retrieve (ie. to my right side as I hold the rod with my left hand) and tapping the rod butt with my index finger whilst retrieving gives a great action. For cob (which I've never caught on jig) I would try the abovementioned advice and try letting the jig sink to touch the bottom before giving subtle bumps and jerks. Remember, bucktail absorbs odour. So, try YUM shad spray, Bang craw oil, Berkeley scent or even rubbing sardine juices on the hair. Good luck and send pictures.
Dingleberry
Sorry Ziggy, I forgot to answer the question on where to cast. Garrick, Shad and Kingies - amongst others -will feed in whitewater. So, don't always aim to cast into perfectly clear water. You're looking to fish areas where there is bait ie. shallow, foam water over reef, or sand gulleys parallel to shore, river mouths etc.
esatpil
Guys,
Im flying to SA on Tuesday for a few meetings,does anyone know where in JHB i can find these lures.
Im off to Mombasa in about 2 weekstime and wanna try them out.
GeraldSmith
Hi Ringo
Yes, those bucktail jigs are AWESOME.  I used a half ounce white one, from Marshie's production line, and with the first cast this afternoon in the Nahoon river with the first lure and a Cob was on!!!  Bumped it nicely on the bottom a few times and then there was no turning back!!
Keep those jigs flying guys!
G
Nepptune
Ringo - Stoked to see the advice paid off and you got into some great fish... congrats mate!!! Make sure to take a camera next time and capture those catches on film for us, would love to see!
