Brake collars
Mike Pike
Hi all , the red and black brake collars supplied with daiwa multipliers should one change them or remove from reel altogether ? what do the various colours signify ? any change in reel if removed ? thx Mike.
rofflign
dunno about the black one's my sealine x30 has red and white one's,I use the smaller white one's,the red one's brake the spool to much for my liking,making me lose distance.
dup-zn
Hi Mike
The colour is not significant.
It is the size of the brake collars that makes the difference.
You will notice that the one set is bigger that the other.
The small set weighs less so the centrifugal braking action is less than the bigger pair.
If you are a novice the brake collars will help you with controlling your spool speed.
It will not however stop you from getting an overwind.
These collars were in both my Saltist and Trinidad and I removed them as I have a quite educated thumb when it comes to casting.
Mike Pike
thanks Dup , will either remove them or change to smaller ones ,thumb does most of the work anyway ! will stiil advise u on the moulds . regards Mike.
Johan S
Well, as a novice I was a bit hesitant to remove mine. I did it anyway last week and just tightened the cast control knob a bit more than usual. Only made a couple of casts since, but all I can say is, I'll never go back to brakes.
Walt
Took collar brakes out of my Saltist 30H and it didn't make much difference at first.So took ring out as well, which brake collars brake against, as arms that collars go on,create a slowing down,as they run very close to this ring or 'Brake drum' for a better word.Tried it on Saturday and the difference is incredible.Haven't had reel long and felt it was holding back when sinker was travelling through its arc.On Saturday,30H outcasted my Grandwave 30 by a few metres.But,to be fair, I'm using a 1 pce rod for Saltist as opposed to 3 pce for G/Wave and this may be the difference.I've had no overwinds and also won't return to brake collars.For a learner,brake collars are the answer.But once you know your reel,it's totally unnecessary.Cheers!
Johan S
Walt, I agree mostly, but I'm a learner and found sufficient 'overwind protection' by simply tightening the cast/spool control knob without the break collars. Just my two cents...
