Braid to Wire
DuRRi
Hi guys.
When using braid for tigers..Can I connect the braid directly to wire? or is mono a must in between? What knot is the best?
Cpt. Hook
DuRRi wrote:
Hi guys.
Braid to mono leader using a double uni knot, leader length around 1.2m, mono to wire using an albright knot
Ryan
Personally what I have seen here with big tigers of Barotse.
Leave the Flouro mono out.
If fishing fly then I use the albright mono to Piano wire.
With braid I have a preference for fishing 42lb Piano I have found that if one ties directly to the Piano I get snapped off here (They seem to hit it so hard that the paino cuts through the braid) So I use the smallest Power swivel I can find normally a 60lb - some may argue that it causes a bubble trail when you have a fish on and cause the other pack fish to bite you off but on Thursday I landed 5 fish over 10LB and another 22 fish of around 6-8lb on the same lure and wire -had to do a fair bit of straightening etc of the woire during the day but this works for me.)
I have also seen in the last week with some very old well experinced anglers that I had as guests last week. They use the soft Nylon coated wire (Thin DIA. too) they do a Bimini in the Braid and then the loop the end of the trace and to this they attach the braid loop using a Cats Paw and this was also very successful and effective....
Hope this helps
DuRRi
so u found no issues with the braid to swivel connection? What knot you using?
thanks for the feedback guys
Cpt. Hook
Ryan wrote:
Jeepers guys to try and explain - maybe the knot has a name but I use it for braid mono etc
Please try explain, we know you wrap the thing-a-ma-jiggy around the whatsumacallit 3 times and then pull this-thing-article through, but we want to see how you do it please :ifishin don't be so cold
