Braid on plastic spool?
goofball
Howzit Guyz!
This is my second post on sealine, and i must say that sealine is awesome!!!!!!
Im using an old Abu 55, this reel is older than i am (23yrs), but has been kept in mint condition by my old man. I am keen to invest in some braid, but am scared of damaging the spool if the braid is put on too tight. The spool is plastic, would it handle the pressure? Dont want to get klapped!
neilg
Braid has no stretch, so it won't stretch/shrink like mono, based on that it SHOULDN'T be a problem.
But since I have never done it I cannot give you any guarentees.
kitefisher
Hi Goofball, I would think that the spool would arguably be safer with braid than mono,due to the less stretch factor.Most "older"bakelite /plastic spools popped from being under severe pressure from the stretched mono being wound on, and not relieved of that pressure timeously.
Please verify this with a few other opinions,before just going for the braid. If you're stiil hesitant I will gladly take the 5500 off your hands, LOL.
P.S Does it have adjustable end caps on both sides of the spool,and levelwind or not.?
What breaking strain were you thinking of putting on?
By the way ,very welcome to Sealine
goofball
Thanx for the quick response guyz. I reckon im gona give it a go. After reading about all positives of using braid, i cant wait to try it!
kitefisher, im not too sure about the adjustable side caps or levelwind - not so clued up on the specs i am, but can try and find out.I want to use braid anywhere from 6-10lbs(haven't purchased yet). One thing i can say is that these reels are a dream! cant compare to any other grinder that I've used.I've got 2 identical Cardinal 55's, will let you know if in future i decide to get rid of them.
Thanx for the advice. tight lines
Marthin
what i would suggest is that you put a piece of cloth around the spool. I've done that with my penn 49 and have 600 metres of mono on their wound extremely tight and i've never had any problems. A piece of normal bandage works the best (the one without the sticky stuff)
kitefisher
Goofball ,  apologies we're talking about different reels,but the same principals apply,take Marthin's advice and stick some crepe bandage on first.That way you'll be sure not to damage a ver special reel.
goofball
Thanx it's worth a try. The reason i asked is because a few weeks ago i popped the spool on a pen 85 using mono (IDIOT!), and have been struggling to find a spool for it. Dont suppose anyone knows where i can find a spool for the pen 85? it's pretty old.
Marthin
Goof i had one that popped 11 years ago because i didnt put on the bandage and i found a stuffed up second hand 85 in a pawn shop about 3 months ago... they are excellent little reels for the boat(langebaan, breede, gouritz), and also perfect for barbel and even better if you have a cano or bait boat for carp as you get miles of 3.5kg mono onto it. Getting a spool is extremely difficult and i had to wait 11 years to find one. I managed to fix the other 85 so im also in the market for another spool if you manage to find one. About 5 years ago i could find one but it was exectly R75 cheaper than buying the brand new seaboy that came out then.
dugongboy
goofball - very very good reel you have there(in its day it was regarded as the best spinning reel available by many people) I have the 54 and the 57 - no problem with putting braid on the plastic spools. My 57 has accounted for a few shoal couta as well as a prodigal of 11kgs.(with 20lb mono).
All the spares (except for the body and spool)are available from mikesreelrepairs.com - I had to replace the line lay cam from wear (too much spinning) so if yours has been used a lot then have a look at that. Have you opened it up - very well made - having a rear drag means you have to keep it clean and also make shure that the line roller is lubed and not stuck, otherwise wou will have major twist.
As good as they are, there are very good spinning reels available thesedays that are better and for a lot less than what that reel would cost today(spinning reels have advanced a hell of a lot in recent years).
Fill it up with 20lb braid and enjoy it!! - just don't break the body.
goofball
Wow, now im definitely going to use some bandage on my Abu. Rather safe than sorry!crickey 11 years!! . I guess i shouldn't get my hopes up to do sum trolling with my 85 this season. Thanx for the insight Marthin!
dugongboy
Use 'self vulcanising' electrical tape on the spool before loading braid - available at electrical shops - very handy stuff.
goofball
Thanx dugongboy, will definitely look into the 'self vulcanising' electrical tape. I really do envy those catches of yours! Its a dream of mine to catch nice couta on light tackle. Myself being a garden route boy, the only species of gamefish that i have caught(and safely released) is Garrick, there are plenty in this area - But after reading Niels articles i cant wait to target shad!
