Hi
Braid has a reputation for slipping knots and apparently the Bimini can even slip in braid. There was a whole long article in Complete Flyfisherman about it and in there they said you have to use waterproof superglue on all your braid knots but the most foolproof is to make a sleeved loop with mono braid or dacron over it like the New Zealanders do here, what do you guys think of this? It is supposed to have 90% knot strength.
Knot Tying Instructions for Super Braid Fishing Line
EUREKA! The simplest knot in the world, the humble granny, when protected by dacron is probably among the strongest fishing line knots you can tie in spectra.
For maximum strength all that is required to make the knot is a metre or two of dacon fishing line of bigger breaking strain than the spectra you are using.
For example, use 80lb dacron for 50lb spectra and 130lb dacron for 80lb spectra. The spectra is threaded through a needle and the needle is fed backwards completely through the inside of the dacron. For bigger lines feed one piece of dacron inside another to double the breaking strain before putting the spectra inside.
A granny knot is then tied into the dacron near the end where the spectra was inserted. This results in a 10% reduction in strength at the granny knot and a vastly increased breaking strain in the last couple of metres of line where both the dacron and spectra continue to the end of the line.
Any secure knot can then be tied to whatever terminal tackle, clip or swivel you wish with real confidence that the final attachment will be 90% of the breaking strain of the spectra.
Fishers who use this method of knotting spectra will be able to tie consistent 90% knots in spectra that vary less than 2% regardless of how poorly they are tied. Absolutely no knowledge of how to tie fishing knots is required.
For more information on how to tie fishing line visit our knot tying guide on how to tie a loop knot
. u funny guy Reefer
