Braid casting problem
xtc
cool - watch for the loop forming on the spool just after you have casted - could very well be where the problem lies - if it is then just get into the habit of either looking, or pulling the line, before every retrieve
Johan Yzelle
I went fishing over the weekend and still the same problem, exspecially when trying to cast harder. My father has the same reel but with fireline, no problem casting that...
I seem to be missing something... Had like 20 casts and then a windup, sometimes a few short after the other...
I'm confused...
Simen
Johan, place a pic or 2 of the reel with the line on, maybe we can see something there.
also its good advice when spinning to once every couple of casts to hold the line tight and get it even back on the spool
Specially when using top water lures, it sometimes shoots out of the water while you are reeling and that causes the line to be very slack on the spool.
Then its in the water again and the line gets wound tighter.
When you cast again the tight windings tend to pull the looser ones with them
chrisv
I have this same problem with one of my reels. Have tried everything to no avail. I'll check out xtc's advice. I even took the braid off and replaced with a 6kg line and still get windknots. Someone suggested that the last eye on the rod is too small. I have tried on various rods with the same results.
Chris
Bingo
Hell, with the price of braid this is not lekker.
Was spinning at Macs yesterday, 5th cast, got windup on the reel, and snapped ±80m of braid clean off. Braid+leader+spoon:(
Think I'm going back to mono for spinning
Astrix
:shock:
I had the same problem on braid and fire line but it seem to apear at the leader knot, when the braid was new I just cut of the mess, spool was less ful and as the braid wetted out it became a lot better, just a lot of patience, but acoording to my experience you gotta "break in" the braid to stop it from overwinds, unfortunately no matter what you do they will apear from time to time, and to my frustration!!!
:fbash
BoomBoom
One simple rule with braid , besides the obvious of over filling a spool !
Once you have made your cast - use your hand to click the bail arm over and wind on slowly till you get tension ! Then proceed with your retrieve !
By doing this you will always ensure no loop on your spool and at the same time be looking after your grinder !
Also as braid gets worn in you less prone to knots !
chrisv
I found that the twist comes only on the cast and only on one of my reels. Never had a twist on any of the others.
