The BG 6500 and 8000 are the same reel body and drag stack. In other words the spools are interchangeable.
The only difference would be the sizes of the spool giving the 8000 the lead on line capacity.
In my opinion if you wanted more distance go with the 6500 spool as its diameter is smaller compared to the already huge spool size of the 8000 which due to its size alone would mean that your first eye would need to be on taller stand-offs from the rod with a bigger eye otherwise you will get line slap.
I have the 8000 as it was the first models that came into South Africa but would of preferred the 6500 for cast ability as when I paired the 8000 to my 10 foot Shimano Spinning the braid slapped against the rod unfortunately meaning I would need to modify the first eye.
The 6500/8000 BG are heavy duty reels, you can catch Tuna on these things, although anything above 50Kg is going to take you a long time and you should be using other tackle in any case, but for a lark it can be fun to hook a beast. I landed a 60Kg Yellowfin on the 8000 last year but the water depth was no more than 80 meters, not once was there any danger of running out of line. The fish took an hour and a half and the reel did the job nicely, but in reality I would not like to do that too often. A beast below 50Kg would be my preference.
For sheer cast ability the 4500/5000 would be better, but then you would have less line capacity and only 3 drag washers instead of the 6500/8000 which has 5 drag washers.
I own both, the 5000 and 8000 but will probably only use the 8000 for Tuna. Its just too heavy to cast all day long for Yellowtail which is my main focus. That 8000 reel is huge and while it would be fine for most medium to smaller class Tuna, in my opinion when you start with the above 50Kg Tunas then you should be using different tackle anyway.
By comparison, the 5000 is about the size of an 8000 Shimano and the 8000 is about the size of a 14000 Shimano.
In my opinion Alan Hawk should also do reviews of the 4500/5000 BG and some of the smaller models too. Not everyone is needed a huge 8000 BG reel size
