Berkley Fireline for trolling
Marcf1
I was thinking of putting 50lb Fireline on my trolling reels, with a 10m fluorocarbon leader, as I'm pretty sure the fireline would last alot longer than mono, and be alot more resistant to damages!
Anyone have any experience doing this (pros vs cons)?
Thanks,
Marc
RoryC
Hi Marc - although I havent tried it myself the only concern I have is that there is no give in braid at all - and at the speed game fish hit they may well snap off pretty quickly - mono has a lot more give which is needed when trolling lures etc? My 5 cents worth.. Nice iggie you landed there by the way - must have pulled string hey?
Cpt. Hook
When braid 1st became a big thing I tried it on all my trolling reels.
The result was a big dissapointment as I had so many break offs as there is no give in the braid and I even went as far as using a very stretchy mono to make a 30m leader and still the line parted.
When trolling you need the give/stretch/forgiveness that mono offers and what I found is that even 80lb braid cannot handle a fish that 30lb mono handles with ease.
What you can do is use braid as a backing and I would not use a wax coated line like Berkley Fireline, but rather something tinner and un waxed like Berkley Whiplash.
Your backing can allow for 100-200m of mono top shot and the only advantage you will get is more line on your spool for that big one that comes along.
Braid also has no abrasive qualities compared to Mono and so again will result in break offs.
Flouro is also no good for trolling as it also has little stretch, is noisy in the water and the knots get brittle fast and burst. Fluoro knots can not reach the same strenght as mono knots.
