Bearing Buddy
NAUTILUS
Bearing Buddy. Can somebody please give me some advice on how to install Bearing Buddy on my boat trailer,I am aware that not many people in S.A know what this product is used for ,but there  must be someone who installed it Thanks:kaykak
NAUTILUS
Thanks ,  but  their web page not very helpfull .Iwould like to know if this product is being used at all in S,A.
juanita
HI Nautilus,
Bearing Buddies are very simple to fit. In the centre of your wheel is a bearing cap.
This steel domed cover or bearing cap is just gently tapped into place. To remove use a fairly large screw driver and gently try and lift it off by inserting the screw driver between the bearing cap and the hub . Work the screw driver all around the cover by gently tapping the back of the screw driver with a light hammer.
Once you have it off gently tap on the new one and fill with greese
Make sure you have the right size as they do vary
NAUTILUS
Thank you Juanita ,do you make use of Bearing Buddy ,If so are you satisfied,Iam awaiting mine from U.S.A. should be here next week.Chris
Patrick
Hi Nautilus, you can buy Bearing Buddies here in SA at most trailer/boating shops. I've even seen them at the Agri Co shop in Langebaan. They're about R75 each and they work well.
Lyne
I'm sure the local one is called Bearing Friend. I have used them and the only problem was that the 52mm one I ordered was so tight fitting onto the hub and the salesman had said they shouldn't be forced on, that I ended up getting the 50mm. Needless to say I ended up loosing one and have now gone back to the 52mm standard dust cover. I might add that putting a new one on was not easy and a lot of force was need. This was on a standard Burquip hub.
NAUTILUS
Yes  a fool is caught every day  .I just paid R850.00 for a set imported from U.S.A. It shows you if you dont ask Sealine you must suffer in silence. thanks for all the advice.
juanita
Correct Lyne, the local one is Bearing Friend
I think I paid R120 a set from Anchor boat shop. Yes they go on tight ,use a heavy piece of wood to gently tap them on. Get someone to measure the the inside diameter with a vernier for you so you get the correct fit.
gerry
I have had the american bearing buddy(metal) on my boat trailer since 1983 and only replaced my bearings in 2005 because I wanted to - not because I had to.My caravan has had the plastic buddy on for 5yrs.have lost 2 because they fell off.Nowhere near the same quality of Bearing Buddy, but a big difference in price.Recently someone in Durban advertised on this website that he was making them here.Hope this helps
Saltyfin
The Metal Bearing Buddy looks very good, I found the RSA plastic ones leak grease out that little breather hole when you put them under excess pressure. I also inverted the axel seal so when you block the breather hole with a little self tapper screw you can pump a good pressure and have a better chance of filling the bearing cavity. Inverting the axel seal comes from MF tractors working in swamps where the bearings lasted longer by keeping the water out rather than the grease in. I only bother to check my bearings every two years, but a visual inspection and give them a pomp after every launch for safe measure.  If there is someone making metal ones - I am interested.
