Barbel rig overnight
Rice Burner
I have a dam on my farm and it is totally overstocked with barbel. My plan is to reduce the numbers by setting a type of "night traps" something like the long liners use deep sea. I don't want to set nets in the dam in order to protect the other species.
Has anyone done this before ? I cannot set 10 baited fishing rods and leave them during the night. Can I set a type of a "long line" in the dam by not using a rod and reel and how is the rig made up ? The only purpose is to harvest them.
HennieB
I'll gladly come and catch some babers :)
I've seen on natgeo they use the long line method in the amazon to catch freshwater fish that way.
Ant86
There are quite a few members from the PTA region , invite a few for an overnight session.
Hi
I have done it before with 130lb line as main line make dropper loops in the main line as many as you like then take snap swivels and make your trace from snap to hook depends on bait witch hook j or circle. Put a weight on the one end and the other end a weight with a float tied to it. Drop your one weight while letting out line clip your baited hooks on pull the line tight and drop the other weight.The float is there to find your line again and to pull it up.
good luck
AYOBA!
I would gladly bring a few rods, as well as my roepstok, if you have other pests like rats and flying rats, I can bring along my air rifles as well
