Barbel & Circle Hooks
Otto
I recently acquired a boat and after watching the "Hier gaan ons alweer" DVD Barbel have become one of my favourite species. I have learnt a heck of a lot and would like to share some of the progress that I have made during the learning curve. When I originally made the decision to purchase the boat I wanted to spoil some of my clients with a pleasant day out on the boat, fishing. Barbel are aggresive, good fighters and I have never blanked irrespective of the weather.
In the early stages my set-up included the normal sliding sinker, bead, swivel and # 3 Mustaq J hook. I had a lot of line breaks and GUT hook ups. Taking out clients and exposing them to that was a big no no. I have extra long pliers to remove swallowed hooks but being honest the damage caused to internal organs was obvious. So I changed the set-up to a sliding sinker, 4 small gummies and a # 4 Mustaq circle hook, tied with a Polymer knot.
The difference has been remarkable, hardly a line break (no knots) and no GUT hook ups. My fishing technique has not changed, as all the fish have been allowed to set the hook themselves against a relatively stiff drag setting.
Circle hooks are definately the way to go! Tight Barbel lines!!
Ant86
Couldnt agree more.
I changed to circles in December and it was the best decision,no more gut hooks and perfect hookups in the corner of the mouth.
What bait do you use because a 4/0 circle sounds a bit small,
I use nothing less than a 8/0 Gamakatsu,Mustad demon 8/0
or eagle claw 10/0 circles. 80% of the time i use day olds,
10/0 is for fish heads.
I use the palomar knot,super strong.
Dean Slater
also, you dont miss hookups, the barble hooks himself, you dont have to be quick getting to the rod, which is a plus if it 3am and you sleepingin a tent.
Unlimited
good stuff...
"van der merwe" hooks works on the exact same principle, have been using them for cats and have never gut hooked a cat, even if you strike, which i do everytime.
Otto
@ Antjar - You are right they are small hooks, but here is the reason why I use them. I am only on the water for the day with clients/friends and the focus is is on achieving results. I have my own "worm farm" and have some really big earthworms, thick like a pencil and 200mm and longer. We load 5/6 of them at a time and sometimes add a chicken giblet or two in between. The earthworms must dangle past the sides almost presenting itself as a little "octopus". The Barbel picks that up in 15 - 20 minutes. When using bigger baits or chicks it lies there for longer before being picked up and that does not suite the one day scenario. The weights of the Barbel we catch vary between 2.5kg and 10kg, for first timers thats a big thrill.
Ant86
@ Dean,that is one of the best features of the circle hook,
We often play poker or something while fishing and the circle allows you that extra time.
@Otto,that sounds like a deadly bait,I might try that on a light stick for some fun.Only problem is like you say that you basically hook up just about everything that swims past.
The only time i will use J hooks again is when the cats swim towards me ,like this weekend at harties,they were picking the bait up and swimming directly at me and all the structure
