Banax Legend 40 or 30 ADVICE NEEDED
Aydee
Good day all.
I currently have a Banax Legend 50 (still unused). So my reason for asking is more a case of wanting instead of needing.
Would the Banax Legend 40 (or 30) be enough for catching in-eds? I realise that they all have a high gear ratio but the model 50 seems to have performed well enough for shark fishing.
With braid as backing, would the 40 have enough capacity to not get spooled?
How plentyfull are spare parts for the 40 ( since most guys are using the 50)?
If anyone has both, could they please upload a picture of the bigger and smaller reels side by side?
Instead of going for the smaller 40 or 30, would a Torium 30 be a better option?
I appreciate any advice you have to offer.
The 40 is rthe same size as the Saltist/Saltiga 40
It will hold 400m of braid and 200m of 0.50mm
Depends on what size ineds you are targeting but it will work ok as a Throwbait reel and will land good size fish. But it is not a shark reel
Mechanically it's the same as the 50, It just has a narrower spool and frame.
FLUKE
I'm not sure Banax make a 30 but the 40 would handle a decent shark in some areas.
I've landed a 70kg Duckbill and a 80+ kg Blacktip on a Finnor 20 and 0,45 line. My reel was spooled with 400mtr 50lb Braid and 300mtr 0,45 and neither of those fish threatened the bottom half of the braid.
The 50 is however the right choice for non eds!
FLUKE
They look real good!!
30 is definitely too small for in-eds, I'd never choose a 40 to specifically Target anything more than spotted Gully's Smoothounds and rays(smaller ones)
Is a 40 big enough not to get spooled NO, but then again neither is a 50, a Torium 50 or a Tiagra50 it's just that the chances of not getting spooled improve as the reel size increases ((r(e(ling but as the reel size increases the bait size increases :spite:spite:fst:
