Baja Dam - Bronkhorstspruit
snyper564
I would like to fish for bass at baja dam in a week or two i know the dam is very big and i have absolutely no idea where to go or what lures to use ill have a boat so getting around wont be a problem any help will be greatly appreciated
:fswim
zucas922
Once you enter the baja dam resort , go as far right as you can , fish that corner of the dam , spinner baits work very well so do brush hogs in texas style , fish the deeper structure and cat tail reeds , you will be sure to land a keeper or 2 that way
rp
Hi there
I fished Baja recently. Zucas is right the best fishing spot is in the far right corner. U can also try and locate the dropoff at the opposite side of the inlet, there are a few gravel beds there. The best I have found for the dam is to use a green pumpkin fluhe Texas Or carolina rig. U have to fish slow.
If u go to the left of Baja u can fish at the inlet on the Nature reserve side. There are nice dropoffs there against the bank. Look for the river bed there. That area is good for spinnerbait and fluke as well.
Good luck
snyper564
Thanks for all the helpful info just wanted to know how is the dam for bass is there lots or is it scarce is it a very worthwhile dam to fish in other words
zucas922
Its not fantastic but its not bad , id say 4 to 5 per half day , depends on how much effort you put into it , can be a very tough dam at times
rrebello
any ideas on bronkies nature reserve? cost? lures that work - if find with bronkies dam its spinnerbaits and texas rigged brushogs or flukes in watermelon red any other suggestions???
snyper564
Just an update went on tues the weather was really bad, i blanked but i only fished about an hour spent 30 min hanging off the side of the rubber duck removing somebodies gut not fun at all will try again this weekend but it looks like the bass are very active.
