Baitrunner / Spinning reels
Hennas89
Hi guys
I'm have always fished, but never understanded everything about fishing. Now I want to improve and catch more fish.
I'm in the market to buy new reels. I want to do the conventional fishing route and need advice. What's the difference between baitrunner reels and spinning reels and which one is the better for conventional angling? Any advice would be appreciated
Fishpaste
Depending on your budget I would opt for the Shimano DL baitrunners range... Baitrunners have an instant freespool drag system for when you are awaiting a take and a separate drag for fighting a fish. Makes life a lot easier.
FOR CONVENTIONAL GO BAITRUNNER AND GO SHIMANO!!!
QAZA
Shimano-no-no-no-no-no
Daiwa-ja-ja-ja-ja-ja
LOL_seal1_
Hennas89
Thank you very much fishpaste. I would definitely have a look at the Shimano DL range. There is so many products on the market. Never know which one to buy that will work properly. Thanks
Fishpaste
There are no baitrunners in the daiwa range if I am not mistaken...
Before we start the age old debate...GO WITH SHIMANO ;)
I had shimano DL10000 which I used for both conventional and specimen without any problems and for over 3 years. Never a days problem!
Hennas89
Thanks fishpaste. Googled Daiwa and couldn't find any baitrunners like you said in your post. Thanks for the info. Will definitely go the shimano route
Fishpaste
Come to think of it...Mias Woodmead (I know I know...)has Tica Sportera reels for around R750 each - 30%
I owned 2x before and they are awesome value for money reels and not too well known in RSA so people steer well clear. They are a USA brand and solidly build!
If you want to go the cheaper route look at the Okuma Longbows.
I would firstly opt Shimano, secondly Tica Sportera and thirdly the Okuma Longbows.
QAZA
Hi Hennas
Daiwa baitrunner reels available on web: Regal, Opus and Black Widow.
1. Are these available in RSA?
2. Suitable for freshwater conditions?
Do not know, therefore the polite question.
Qaza
dewalds
Hi there,
Daiwa does have a great range of baitrunners,
BUT
Out of a competitive point of view Shimano is the route to go as you can quickly and easily change spare spools should you need to. Shimano also does have a larger range of baitrunners than Daiwa. Make no mistake, daiwa is a great brand, and I use allot of their reels for saltwater and barbel angling.
The main point however is, for conventional bank angling: go with Shimano.
Buy the best shimano you can afford, and if need be, save up an extra month before buying. Personally I wouldn't buy anything less than a XT model reel. I've got 4x XTRB's, and they work hard, fishing up to 5 times a week, and they are still as good as new!
Good luck with the decisions, and happy shopping!
Fishpaste
For someone starting out and not fishing competitive and not 5 days a week the DL is a better choice. XTR is way overpriced. When your DL comes to need a service upgrade the bearings and the whole shibang! My 2c
aruthenberg
Just my view.
I have been fishing for close to 12 years now. I was fortunate to start on Shimano's and to date the ones I started with still works 100%.
I recently (a month ago) also decided to upgrade my reels and started looking at what is in the market. After looking at a lot of reels I had to choose between the Daiwa Black Widow 5000 (+/-R1000) and the Shimano DL6000RA (+/- R1000).
I chose the Shimano DL's for the following reasons:
1. I never had any issue with Shimano
2. The 6000 Shimano's spool is slightly bigger than the Daiwa's 5000 spool, making casting slightly better.
3. The Shimano's drag system seems a lot smoother
4. The Shimano have the double handle so it is easier to start reeling
5. This was most probably the most important factor that made me decide on the Shimano's. The fact that both the Baitrunner Drag and normal Fish fighting drag adjusts on the back of the reel. On the daiwa the baitrunner drag adjusts at the back but the spool drag at the front.
Please understand that this is only my views and my preference.
I can however guarantee 2 things. Shimano is really good quality and I got them for an awesome price.
