Aluminium Strips
Homie
Hey Guys,
I'm looking to do some Mods on my takle box, any idea where I can get this from ???
Thanks::tight:
Walt
Hi Homie.I'm not exactly sure what you're after and what the application will be.But,having been in the Blinds business and making use of aluminium for the tracking where the louvres operate from,perhaps one of the Blinds companies can point you in the right direction to an aluminium supplier/dealer whereby you can obtain what you're looking for.Probably doesn't answer your question,but just an idea.Cheers!
Llewellyn
hello Homie
probreer hardeware winkels soos MICA hulle hou gewoonlik kleiner profiel AL aan, anders is deer winkels soos Non Ferouse Metals in JHB wat jy kan probeer.
Llewellyn
Homie
Thanks Walt,
Looking for stips about 5cm wide and between 3-5mm thick, or alternatively, even a decent sheet of about 3-5mm thick.
I want to rivet this to the bottom of the Blue tackle box, and also use the strips to re-enforce the bag,
Thanks, will try some of them
Homie
Dankie Llewellyn,
ek sal daar probeer.
Verskoon my afrikaans, ek sukkel a bietjie om te praat, en om dit te skryf is a hele ander ding !
skrops
eish bro, 15 x 3 will probably be arround R60 for a 3 m length. dunno, that is a wild guess, can't remember has been many moons since last I bought some.
Walt
Think you've got your answer but if not see if there's a Wispeco in your area.They're major suppliers of Aluminium and I found them cheaper than other outlets.Cheers!
Kumz
Dude bring your box along one day ..lets see what you wanna do 1st & then takeit from there .
Pull in to my possie anytime !!!
I am sure that we can make plan ....
Kumz
Ja pullin will sort you out ..
You dont want to add too much weight cos after the 2nd km .
Every gram weighs a kg ... lol
