airbrushes
eviltoy
Hi Guys
I  can get a Aztek a430 for a good price. The external casing has seen better days but it seems mechanically sound. Have any of you guys used one of these seems really cool from a cleaning perspective as its spray out with cleaner and thats that
Can't comment, sorry! my stuff is junk!
One think though, you can clean them like that after 2 or 3 uses but you WILL strip it to clean it. Otherwise you risk messing up a job because dry bits start coming loose and stuffing up hours of work.
eviltoy
Thats the awesome things about these airbrushes its just the nozzle that needs to be sprayed out. Thats the drawing card for me
I googled it, have no idea.
This is the brush I use. I don't even know the make. It is quite nice because you can control the the paint flow as you paint. Pull back on the trigger and it allows more paint through. Works well, cost me R350. But it does need cleaning. But so simple to strip and clean.
I also have 2 of those that don't have a needle and it works fine, just not as accurate. I actually use 1 for base coating. It has a large nozzle, I think 0,7mm. The other one is 0,2mm but not accurate at all. It too needs cleaning. The atomised paint sticks to the air cup in front. If I don't clean it periodically I get bits flying out of it onto the job.
tackle whore wrote:
forget it PM me for a list of reasons mate .
Mark, would you mind posting up what brushes you use for what. I am keen to upgrade my stuff and would like your opinion. Something more along the lines of detailing work.
Would appreciate it.
B
