Aerial Thermography for Bass Fishing
Fishton
Deciding where to target bass on a large body of water is a bit of a daunting task.  The old saying of “80% of the bass are in 20% of the water” is a fairly accurate statement, personally I feel it’s more like 90/10 lately.  Fortunately there are tools at our disposal to make these large bodies of water ‘smaller’.  These tools include Google Earth, sediment charts, DrDepth charts, high speed bass boats, SideScan sonar, and thermal imaging – otherwise known as Thermography.
It is pretty much a given that if you can find the warmer water you will find the fish.  The biggest problem with measuring water temperature with our fishfinders, is that we are looking at surface temperature, and therefore have no idea what is happening just a few feet under the surface.  Then we run into a host of problems with area covered and data capture for comparison, giving us a very limited thermal knowledge of our surroundings.
Aerial Thermography however is the quickest and most accurate method of collecting reliable data for temperature comparison.  This exercise is carried out using a thermal imager with a relatively fast refresh rate.
The aerial survey is best carried out with a small plane or helicopter with the door removed for easy movement of the camera.
This exercise is to be carried out at first light, BEFORE the sun has had a chance to start warming the water surface.  The other reason for doing this at first light is that the warmer water below the surface has had a chance to well up over night thus influencing the surface temperature significantly.
Thermogram 1:-
This little overgrown cove is clearly holding some war water. The other interesting thing to note here is how the warm water is feeding into the shore below it, but not above it.  So the first area you would target here is the little cove, and then along the shoreline below it.
Thermogram 2:-
This bay has a vertical rocky face in area 1, and is holding some very warm water right on the shoreline, so this would be my first choice.  The second spot to run to would be the little cove on the bottom right, with the last spot for this area being right in the back of the bay on the right hand side bank.
Thermogram 3:-
This is also a very interesting spot because you can see how the two coves have cooled down substantially over night, but the main river channel is still holding warm water very close to the points on these coves.
sustan
i have access to a thermal imaging camera and from what i remember you cant be too far away from what you looking at...how low do you go with the plane? maybe its a different type of camera...very cool thing to play with and extremely accurate!!!
i prefer the black and white setting which allows you to see more detail
Fishton
Wind / air movement (Atmospheric Temperature) between the lens and the subject obviously plays a big role in the accuracy of the actual temperature measured. But it does not really matter in this application because you are looking for the Delta T. (rise or fall temperature)
cranky
please give us more details about these thermograms...
in thermogram 3...it looks like the main body of water is warmer than the back of the coves would this be because of the depth of water...and how would the depth affect the water temperature?
how would the current affect the water temp.
the last question...how did this scan influence your results in the IBC...i noticed this scan was done a day or so before you fished the IBC.
i think i will try this at shongweni dam...the next time i go there and see how effective this method is...i have noticed as we kick around the point into the river you can feel the temp drop on your legs...how early would i need to do this so i can get an acurate reading...would the sun reflection on the water affect the result?
cranky
i decided to try it out today and the goods news...thumbs up to john...ive never thought of doing this before...both rory and i only caught fish in the warmer sections indicated in the image below to the left and right (marker 2 and 3)
you can cearly see the cold water coming out the river...as you mentioned the actual temperatures are not important (temperatures where confirmed to be correct as indicated on the markers by a boat with a fish finder)...but as we go into winter..the smaller dams are affected  more by the cold water coming into the dams...a new toys just been added to my tackle box.:wfish
Fishton
That is a great example Ian! 10/10 When you get a chance, book a flight with Geoff or Noel of Light Flight in Cato Ridge - you will love it. That little Aeroprakt is a fantastic little plane. R1000 per hour.
gt40
does one have do this once off per dam to get a idea or every day?
cranky how did you do it?
