aerator pumps
cranky
anyone have a diagram of the raker X16 livewell configuration and pump system wiring diagram?
there are 4 pumps and each livewell has 2 compartments...trying to figue out which pumps connect to the timer.
the pipng is a problem because the water fills both livewells all the time because the pipes are not plumbed correctly
i need to figue out how long the pipe above the T pieces must be.
cranky
i have manged to find info about livewells...
the way i plan on setting up the livewell...
the filler pumps will connect to the selector switch which has a manual/auto function...
there is and overflow chamber behind the livewell where the water is released...
the aerator pump which was connected as a drain pump will now be coverted to a circulating pump...
we found it is better to keep filling the livewell with water rather than just circulating it.
the fish seem to be a lot more lively when they get taken to the weigh station.
