Adjustable transducer mounting bracket
sea dweller
Does anyone know where I can get an adjustable transducer mounting bracket, made up or already made in Durban. I have found one guy but he wants to use 21 mm tube and it's big and looks @#$%. I had a new trailer made and every time I load the boat on the beach the transducer got ripped off, so I mounted it higher and now it doesn't work very well.
Any info will help.
Fishton
Replace the transducer with a Airmar P66. Not only will your sonar work better, especially at fast trolling speeds, but when you launch you simply un-clip it from the bracket. And when you beach, it will automatically release and flip up.
And they are super affordable.
sea dweller
Here is a picture of an adjustable mount I found on a Aussie website. Fishton, I will give you a call today about prices etc.
Fishton
Wow, that is an awesome design. Thanks for the post.
I will have a few of these made up, maybe include a pop-release system in case one forgets to lift it when beaching. ;)
blaasoppie#1
In case you need a bracket idea for a pirogue; added bulbous bow to prevent drag on the bracket as it had to sit low in the water - works like a charm.
