Abu Ambassadeur 7000i Help Needed
Mbotyi_boytjie
Hi Guys
I have a left handed Abu Ambassadeur 7000i multiplier.
Standard this reel comes out with bushings instead of bearings.
1) Why does it not come out with bearings?
2) Is it a good idea to try replace the bushings with bearings and if so can it be done???
surfaMIKE
For the price you would expect a bearing or two ne?
Why, I dont know, but bushings hold up better in a very salty/wet/harsh environment and require less maintainence in these environments. If a bearing is looked after very well though, it will outlast a bushing by miles.
My dad's abu 7000i is more than 20 years old, and if memory serves me correct, only has bushings. No replacement parts needed thus far, and my dad used to wade alot with his abu when still living in Cape Town. The reel still casts smoothly and far, its just the drag thats gotten very sticky
Cant comment on being able to replace the bushing though, sorry
Dont know why most people dont like bushings, they simple and tough, albeit not as good as bearings when it comes to casting distance, but hey each to his own
Riaandl
I'll say it may be possible to replace it with bearings if that size bearing is obtainable. Might cost you a arm or leg. If you can give me the sizes I can have a look if that is a standard bearing
kitefisher
Mbotyi (rather late than never)
When last I replaced bearings on a 7000 Abu they were 3x10x4's,and they were surprisingly cheap,much cheaper than most.Best bet would be to measure one of your reel's bushes ,or take it along to the Bearing-shop for them to measure. The casting difference is roughly 10% better with the bearings as opposed to bushes.
Your reel looks like the newer range Abu's,but knowing them (Abu) ,they must be very hardpressed before making any changes in design and bearing sizes,so you will more than likely have joy with the 3x10x4 bearings.
