CHAPTER 1: How to Behave When You Lie Two on the Ladies’ Tee
CHAPTER 2: How to Explain Yourself at your First Lesson Without Doing So in a Falsetto
CHAPTER 3: What to Do if They Duck on the 5th When You Yell “Fore†on the 11th
CHAPTER 4: What to Do When Your Ball Retriever is Not Long Enough to Get Your Putter out of the Tree
CHAPTER 5: The Difference Between a Game that is a “Problem†and a Game That Is a “Messâ€
CHAPTER 6: What it Means When You’ve Been Assigned an 11:07 a.m. Tee Time on the Final Day of the Tournament, and You Know the Awards Ceremony is Just After Lunch
CHAPTER 7: What to Do if You Hit the Ground Before You Hit the Ball
CHAPTER 8: What to Do if You Hit the Ground Well, Before You Hit the Ball
CHAPTER 9: The Proper Moment to Announce that Someone Has Chosen the Wrong Club
CHAPTER 10: The Importance of Knowing a Banana Slice is Not Always a Piece of Fruit
CHAPTER 11: Body Blocks and When to Use Them
CHAPTER 12: When to Approach the Clubhouse Instead of the Green
CHAPTER 13: What it Means When the Only Way For You to Hit a Good Ball is to Step on a Rake
CHAPTER 14: What to Do if You Lose Your Mind Before You Lose Your Ball
CHAPTER 15: When to Regrip Your Ball Retriever
CHAPTER 16: The Importance of Carrying a 95° Wedge
CHAPTER 17: How to Hit a Ball on Your First Try
CHAPTER 18: How to Behave When You Hit the Ground Well and Do Not Hit the Ball at All
CHAPTER 19: When to Tell Your Opponent “You Know, You Really Should Finish Your Sway, Before You Begin Your Lunge.â€
CHAPTER 20: What it Means When Your Partner Hits the Dirt
CHAPTER 21: How to Hit the Ball on the Roll Without Losing a Stroke
CHAPTER 22: The Importance of Remembering that Some Courses Play “Lower†than Others
CHAPTER 23: What to Do When You Run Out of Excuses
CHAPTER 24: Your Rights When You Find Your Company Logo Balls in the Used Ball Basket in the Pro Shop
CHAPTER 25: Understanding Your Options When Your Next Shot Has to Carry Over a Water Hazard
CHAPTER 26: How to Handle Your Caddie’s Hysterical Laughter
CHAPTER 27: What a Good Practice Swing and a Bad Attempt Have in Common
CHAPTER 28: Sounds to Make on the Occasion of Missing a Fourth Putt
CHAPTER 29: On Wobbling
CHAPTER 30: What to Do When There is a Foursome on the Green in Front of You and You’re 115 Yards Away
CHAPTER 31: Hyphenated Insults to Use in Tense Situations
CHAPTER 32: What to Do if You Find More Balls Than You Lost
CHAPTER 33: What It Means When They Compliment Your Driver Rather Than Your Shot
CHAPTER 34: What to Do When Your Pause Becomes a Seizure
CHAPTER 35: The Most Painful of Golf Comment in My Experience of “Playing†Golf
CHAPTER 36: What It Means When Your Partner Actually Replaces His Divot
CHAPTER 37: How to Obtain Golf “Handicap Permitsâ€
CHAPTER 38: Utilizing the Laws of Mathematics to Calculate the Speed of a Player’s Downswing as a Function of His Handicap and the Speed of His Backswing
CHAPTER 39: When to Point Out that Nonchalant Putts Count the Same as Chalant Putts
CHAPTER 40: What You Can Learn From Other People’s Divots
CHAPTER 41: How to Fade the Divot . . . to Draw the Divot . . . or, Maybe More Important, to Put Your Divot on in Regulation
CHAPTER 42: Why You Should Hit the Ball on Your First Try
CHAPTER 43: When to Use the Hug and the Kiss in Lieu of the Devious Drop
CHAPTER 44: How to Invoke the Law of Gravity to Modify Your Score
CHAPTER 45: When You Splash into the Water
CHAPTER 46: Why You Should Never Exaggerate Your Scores by More than 10% in Either Direction
CHAPTER 47: The Vital Importance of Punctuation and EMPHASIS (P&E) in Describing Your Game
CHAPTERs Coming in the Third And Final Book Of The “Putt Trilogy,†Entitled, Why Bother Lining up Your Fourth Putt
