A few questions on traces and baits
reynard
Hi Guy's i have a few questions i need help on.
1. If i have pre made my traces with mono line how long can they lie in the tackel box before redoing. Any recomondation or ideas welcome.
2. With all the diffrent baits and target species. How will one deside when to use a sliding second hook and when to tie it down ( snell )
Thinking of this trace ( Thanks Trophy )
reynard
Nobody with a opinion on this.
I have tried to search it in the forum but the questions does not get any hits.
Please assisst as i want to start making my traces
Def-e-nition
Reynard , just give the guys some time . We're all obviously surfing sealine , while at work .
Traces , as Long as the Loop is Not too small , will last pretty long . 2 years? how Long do you WANT em to Last ? you'll lose em before then buck ...
DO not expose them to too much sun either .
More to follow .
reynard
More to follow .
HI thanks for the reply.
I was planning on letting them sit for about a month befor i am heading off to henties. But i want to fininsh them befor hand so that i can see what is missing and fill the old tackle box befor i go. As i will be at Myl 108 i do not want to run out of tackel. Its a 100km then to the neerest tackle shop.
Sailfish
Reynard you can keep them long times if you pack them right. Make sure your hands is dry and no moisture on the hook itself.  Keep the sinker separate and insert each trace individually in its own plastic bag with a slide zip close. The plastic bank bags that you get will be perfect. When you want to use you simply need to tie the sinker and fasten to mainline and walla. You can keep them like this for years if stored in dry place and like Def-e-nition said, out of direct sunlight. Have a safe trip to Henties.
drkobus
I do all mine for the season before hand. Store in plastic bank bags. After fishing rise and wind dry. Store in plastic for next fishing trip. Keep out of sun. I always use sliding hook with any tipe of bait.
