3 piece rod sliding
Johan
Is it advisable to slide with a 3 piece rod? A friend told me that it will work out the joints where the rod pieces fit into each other
GOJ
Hi Johan,
One could argue that sliding could "work out" the joints of a multi piece rod, but personally I feel if the joints are correctly seated, there should be no problem.
Personally on my Magnum XXH I have sliden out upward of 150 baits ranging from a 100 gram mack head to whole bonnies and cuta heads up to 3 or 4 kg. And my joints are as tight at the day I got the rod.
