220V Syncronous motors
I got some 220V synchronous motors for paint jigs or rod building. They are brand new.
R100 each
PM me if interested.
mudcrab wrote:
Theyre microwave turntable motors,might work for chicken spit braai maybe
They are in deed the same. They are also used in appliances like aircons to turn the air direction fins. Suppose you could use them for anything really. Will definitely work for a small spit braai. The motor is more powerful than the one on my webber spit braai. Bonus is no transformer is needed, which will cost more than the motor alone.
Shannon got the last one, so I'm out! I will order a few more, I have to order some other goodies and it takes about a week to get here. It just means that you will have to wait a week for them if you still want.
Bennie
AndriesH
Got mine yesterday, thanks Bennie.
It went into the workshop with the other 2744399276151 things and projects I have planned.
AndriesH
Note one thing:
Being a synchronus motor, means that the speed of the motor is directly linked to the supply frequency - 50Hz.
If you want to control the speed of the motor, you have to control the supply frequency.
This is therefore a constant speed motor and you can change this constant speed via pulleys or gearboxes, but constant it will stay, unless you change the supply frequency.
Reefman wrote:
For rodbuilding, how many of these motors would you need? Just one, or one either side?
I'll take 2 Bennie!
Only 1 motor.
You need a cup type bracket to go on it with 3 screws. You place the large end in the rod in the "cup" and lock it in with the 3 screws. On the other side you have a base with 2 rollers in it. Usually you fit "O" rings in the rollers/wheels to it doesn't hurt the rod.
I can make the "machine" for you?? I'll PM you a price.
