Species: White Steenbras
Location and Date: Southern Cape 3 April 2012
Fishing Tackle Used: Elbe Waverunner, Diawa Sealine 50, .40mm KFGA and .65mm leader.
Weight: 96cm TL (89cm FL 12.7kg)
The water looked so good in front of the rocks that I decided to try the spot barefoot as I did not bring my rock shoes along. I had to use my lighter rod and reel combo as the gully was wide and the bank looked perfect at the back.
I cast my 5oz cone sinker and 3/0 Mustad big red baited with a liberal amount of prawn on to the foaming bank. A slight bump and the next moment the rod is flattened. I lift the rod setting the hook, I’m not prepared for the power of the fish as it takes line at will and I start to worry as I know there are broken reefs at the back. I slowly start pumping the fish closer, as it reaches the sandbank again, it decides to make another run.
I work it back and over the bank, into the gully where it uses the slight rip to its advantage, making me follow it over the mussel and barnacle encrusted rocks. I bring it back slowly and a helpful wave helps it into the rock pool at my feet.
Before the water pulls back a helpful angler grabs it around the body and lifts it onto the rocks where I’m standing.
My biggest Steenbras ever! I quickly measure it. The fisherman takes a photo of me and my catch, after tagging the beauty; I slowly revive it and release it back to fight another day.
