Hi Naruto how long do you make you sinker line from swivel to swivel as the hook length is +- 13 cmUsing a clinch knot I tie the line on to the swivel. I hold the spool between my legs so I can pull the line tight and this helps to wind the line nice and neat to form the clinch knot. I tied these so the whole hooklink is +-13cm long in total. Only then do I cut the line from the spool.
Mine is between 20 and 25cm long.Naruto wrote:Hi Naruto how long do you make you sinker line from swivel to swivel as the hook length is +- 13 cmUsing a clinch knot I tie the line on to the swivel. I hold the spool between my legs so I can pull the line tight and this helps to wind the line nice and neat to form the clinch knot. I tied these so the whole hooklink is +-13cm long in total. Only then do I cut the line from the spool.
jammer man het nou net gsien jy het klaar gese die skag lyn is 20cm-25cm lankhi Nuruto
sal jy altyd jou hoek lentes 13cm hou
maak jy ook altwee jou hoek lentes ewe lank
die skag lyn van die strop is 25cn lank genoeg of moet dit langer of korter wees
thanks man dit is altyd lekker om jou post te lees en dankie dat jy jou kennis met ons deel
I have changed over to the loop not long after I made this thread. Works much better than a swivel and it is even possible to slip the sliding hooklink off if needed...Hi N,
have you ever considered a small loop for attaching the trace to your clip swivel? Not only is it a lot easier to slip a loop over a clip-on, especially when you're catching alot of fish and changing traces regularly, you can also hang it from the "U" of the rod rest which makes baiting up so much easier and best of all, you eliminate a swivel.
You can also consider slipping a "gummy" stop over the main line, below the loop. I normally make the main line on my Rietvlei ±35cm and use the "gummy" to "lock" the top hook closer to feed. When fishing in venues where I may experience silt or shy fish, I'll move the "gummy" to the top of the trace, allowing the top hook to move as far away from the feed during the cast, as possible.
Enjoy :fishn
PM Enigma as he is the man to talk to about Awa-Shima...Hi Guys, I happen to find and was inquisite to see what it performed like and let me tell you one thing, this line surprised me beyond belief. Super strong, soft, abrasion resistent, super high knot strenght the only problem, super scarce. THe line: Red Bravo from Ion Power Awa-Shima. I asked Western Accessories to get me some but still waiting a reply. Don`t take my word for it go test it yourself!!!!!:whisp:clap12
