Howzit guys,just want to know whats the dimesions for the bearing that will replace the bush on the Toriums 30 drive shaft?I stripped the reel last night,measured the Outside(9mm) and inside diameter(5mm) of the bush and then put the reel back together.I forgot to measure the bushes width.So if you guys know whats the width,it would be much appreciated.Dont want to strip the reel again,that cerclip is in a freaking difficult place.Thanks
